nokia x3 fake charging hello mates nokia x3 is indicating charging wen i insert the charger . but battery is not getting full.. no betty ic for dis model . i changed the power ic . same problem. any solutions?????????? |
First Of all U have to chk the PWB impedance to The GND, This should be <1 meg ohm, IIf this is correct u have to check the BSI line ,coz BSI line Btemp line. If eeverythig is OK the next step is the POwer IC trouble shppting |
Bcs this problem is also faced by btem................ |
change is power ic 1000000000% ok test by solution |
First check the chager jack ,I found one phone contact connect to PCB not good after clening it charging ok.:) |
