04-20-2008, 11:25 | #1 (permalink) |
Insane Poster Join Date: Apr 2008 Location: Philippines
Member: 743358 Status: Offline Sonork: dhie2424 Thanks Meter: 6 | nokiaNGage QD CAN'T POWER ON WHATS PROBLEM IN FLASH??? heres my flash in mtbox in the middle it hangs... Processing File: rh2940.0c1 Boot... ASIC ID: 1081 WD2 BT2 w3_2nd.fia w3_amd.fia 842F5762B303ADAF486E8340F414 w3_cbusb.fia Configuration Info (9F): Number of Flashes: 4 00000000: Amd, 0001 007E 0016 0111, 10 02000000: Amd, 0001 007E 0016 0111, 10 04000000: Amd, 0001 007E 0016 0111, 10 06000000: Amd, 0001 007E 0016 0111, 10 ExtBUSC: 4000 00EA 7001 00EA 7301 00EA 7601 00EA Erase[17.25 MB]... request erase [00000000 to 0000FFFF] request erase [00010000 to 00EFFFFF] request erase [02000000 to 0223FFFF] Waiting response for 600 Sec...in 25.75s Flash[17.46 MB]... Bluetooth data is 187796 bytes long BlueTooth flash sent and then hangs there... heres my flash in UFS process failed... 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x00FFFFFF,0001007E,Amd 29BDS128J Fl1: 0x02000000-0x02FFFFFF,0001007E,Amd 29BDS128J Fl2: 0x04000000-0x04FFFFFF,0001007E,Amd 29BDS128J Fl3: 0x06000000-0x06FFFFFF,0001007E,Amd 29BDS128J Algorithm: w3_amd.fia, w3_cbusb.fia, Ver: 4.52.0 Algorithm Ok, MSID: 842F5762B303ADAF486E8340F4 Decoded MSID: 3E4EBAF7-0040C941-A8000000 Encoded FAID: ADCAC8AC-BFA5206A-1FC92408 Area1: 0x00000000-0x0000FFFF Erased, Time: 00:00 Area2: 0x00010000-0x00EFFFFF Erased, Time: 02:19 Area3: 0x02000000-0x0223FFFF Erased, Time: 00:21 BT MCM (21) Image Found: 0x0002DD94 Write Error: hDat 14, at: 0x02000000:08 Process Failed, Repowering Mobile plsss....help whats the problem in the flash...thanks for the help!!! |
04-21-2008, 09:54 | #3 (permalink) |
Member: 743358 Status: Offline Sonork: dhie2424 Thanks Meter: 6 | where can i find the flash ic in nokia ngage-qd??? do you know where can i find the nokia pcb diagram with name of ic like flash ic, upp, pa etc. ??? thanks for help hope it is the solution to problem...thanks! |
1200/1208 power on in fbus cable but can't power on in battery solution here | joauz | Nokia Hardware & Hardware Repair | 6 | 12-17-2008 06:29 |
nokia7250i after flash not power on whats problem??? | dhie2424 | Nokia Hardware & Hardware Repair | 4 | 04-29-2008 21:06 |
nokia n-game QD power on, white lcd in 10sec and off! | grassbright | Nokia Hardware & Hardware Repair | 2 | 09-23-2007 10:53 |
N-GAGE QD Can't power on whit batt,With UFS power on oke... | Mr.XXX | Nokia Hardware & Hardware Repair | 2 | 07-18-2006 16:38 |
Can't power on the phone when flashing it. Why ? | blablabla | x1x to x45/x50 | 2 | 08-09-2000 22:24 |
