Old 09-12-2004, 15:53   #1 (permalink)
Member: 18057
Thanks Meter: 64
in normal mode phone is ok ,not in batt
hi i have one 6310, 3200 8310 , same prob.............
with griffin put in normal mode phone in insert sim, or with batt ... contact service..... what is this stupid prob...... . all trys in ufs , so ........ i need conformation...... about fault hardware or software ?????/
@kki
Old 09-13-2004, 10:46   #2 (permalink)
Member: 18057
Thanks Meter: 64
@azampk
thanx for reply, i have 2300 ,1100 no network. all receiving areas r ok, but when factory reset , manually in phone only shows hutch ,no networks bars show. so azambhai this is conform black guled ic, same looks like hager ?? i know its different ic. i think uem is ok na??
@kki
Old 09-13-2004, 13:53   #3 (permalink)
rajiv007's Avatar
Member: 78767
Sonork: 100.95137
Thanks Meter: 566
mr akshay
both problambs are software prob not hardware for 1100 & 2300 write good pm file and unlock this will solve your net prob.
for contact service flash with good files, write good pm and unlock it
this will solve your prob.
if this will not help you then you need spe flash files i mean rpl files
Old 09-13-2004, 15:34   #4 (permalink)
Member: 79725
Thanks Meter: 5
hi
change battery connecttor
bye
Old 09-13-2004, 16:43   #5 (permalink)
Member: 18057
Thanks Meter: 64
@mtmc
what a funny ans........................
@kki
Old 09-14-2004, 20:03   #6 (permalink)
Member: 18057
Thanks Meter: 64
@azampk
thanx very much for your all replys. thanx
@kki
Old 10-14-2004, 23:00   #7 (permalink)
Member: 39245
Thanks Meter: 43
Change UEM will solve ur problem man...
Old 10-15-2004, 10:11   #8 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
can i replace the UEM with OLD UEM from other phone? Or it must be replacing with NEW UEM?
Old 10-15-2004, 10:44   #9 (permalink)
Member: 63385
Thanks Meter: 3
Change NEW!... UEM can only be used once per phone... U shuold also have to program ur UEM after installing it...
Old 10-15-2004, 11:00   #10 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 497
not UEM Prob
Prob of Pm values is there
Full Erase Your Phones using 7250i_Fullerase.bin
Flash with Latest Firmwares & write Pm Values & Unlock
All is Done
70% case solved by this
If Still Prob then Re-Flow Flash IC & UEM if Possible ...
Old 10-15-2004, 18:58   #11 (permalink)
Member: 18057
Thanks Meter: 64
@all
thanx for reply .
@kki
Old 10-15-2004, 19:29   #12 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
@ merulez29
thanks for your info, but may i know what is the code which is compatible for ALL DCT 4 phones? i mean the UEM can be use on EVERY type of DCT 4 phones, so that i don't need to get the UEM separately for each model. Can you list down the CODES for me which is the COMPATIBLE UEM for the DCT4 phones.
1 type of UEM for ALL type of DCT4 phones.
Thanks In Advance!
Old 01-04-2005, 19:08   #13 (permalink)
Member: 847
Thanks Meter: 36
Thanks,
Aamir_Zia
Good tip..
Regards
Sjakie
Old 01-18-2005, 16:25   #14 (permalink)
Member: 18758
A good pm file from support areea + full flash solved my problem (1100 in CS with battery, ok in normal mode)
Thx!
Old 05-27-2005, 22:30   #15 (permalink)
Member: 16830
Thanks Meter: 32
i had same problem with 5100, 7250. after i flash it with ufs, show contact service. u can repair wirh uem changing. work`s for me.
V3x lcd black in normal mode, ok in boot mode fethi Motorola P2k 6 10-01-2010 10:29
nokia 3230 its not coming in normal mode shakil143 Nokia Hardware & Hardware Repair 2 12-04-2009 08:17
7250i ok in normal mode But Amir-SkillZ UFS2 + UFS3-Tornadoflasher 11 09-14-2005 14:38
PST can find c350 when I put it into Repaire mode, but not in normal mode, why? flysand Motorola P2k 3 04-16-2004 11:24
Need to remotely switch on phone in normal mode kyiv Old Ericsson Phones & Sony Phones 0 08-20-2003 03:10
Page generated in 0.21461 seconds with 10 queries
