Old 03-11-2008, 19:37   #1 (permalink)
Member: 104088
Νokia 6600 Charge pins short circuit
Hello!
I have a nokia 6600, which couldn't charge and when i put i pluged in the charger, the charger produced i high pitched noise.
I dissassembled the phone today, to check the connector, but to my surprise it wasn't the fault. But while i was checking the pcb, i used the buzzer with my multimeter to see if there is any short circuit, and it did at the charging pins.
Any solution? Thanks!
Old 03-12-2008, 04:52   #2 (permalink)
rk19801's Avatar
Member: 238252
Thanks Meter: 81
change charge diode...............
Old 03-12-2008, 05:42   #3 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 524
bro,
try to change charging diod,
and post your result
Old 03-12-2008, 07:30   #4 (permalink)
Member: 429983
Sonork: 100.1604691
Thanks Meter: 59
hi bro
check ur pcb if charger +supply and - supply is short in ur pcb tell me
i will give u a solution
Old 03-12-2008, 16:30   #5 (permalink)
Member: 104088
Originally Posted by khansahab View Post
hi bro
that's what i said
Which is the charging diode?
Old 03-12-2008, 17:27   #6 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
Re:
Originally Posted by AquaSonic View Post
" brother here comes ur charging diode"
Old 03-12-2008, 19:22   #7 (permalink)
Member: 104088
thanks everybody! However i am not quite sure were to find one... do electronic shops sell these (i am talking about shops with ICs, connectors pcbs etc)
Old 03-12-2008, 19:35   #8 (permalink)
Member: 706300
Thanks Meter: 147
Thumbs up re:
" if u remove it, dont worry it is not required to fix the other but important thing is by removing it wt is the position 'is the short over now'"
Old 03-12-2008, 20:19   #9 (permalink)
Member: 104088
still PCB charge pins sort...
Old 03-12-2008, 20:36   #10 (permalink)
Member: 706300
Thanks Meter: 147
re:
" bro remove r22 & check the short"
Old 03-12-2008, 20:56   #11 (permalink)
kailash_gm's Avatar
Member: 101117
Thanks Meter: 466
is ur set is working
if yes check from other set that on charging pointt
1 ponit is gnd
2 point +ve
if +ve point is short check that traack from other set
my soln is from +ve point track goes to diode
ur point downside is shorted
so just give a blade to cut the track going to diode then check by jumper directly
post results
Old 03-12-2008, 21:36   #12 (permalink)
Member: 104088
i have to ask you to post a picture.
kailash_gm unfortunately i don't have another headset
Old 03-13-2008, 08:34   #13 (permalink)
Member: 706300
Thanks Meter: 147
Re:
" HERE IS THE PICTURE"
Old 03-13-2008, 09:12   #14 (permalink)
Member: 390359
Thanks Meter: 30
here is the your solution bro.
apply my method
Old 03-13-2008, 10:59   #15 (permalink)
Sagitarious's Avatar
Member: 615730
Thanks Meter: 256
good picture keep it up................
p1i charging pin shorts muradd Sony Ericsson Hardware Repair 0 11-06-2009 08:07
..::d820 100% short charging pins solution::.. HUM Samsung Hardware Repair 0 03-18-2009 02:17
2650 not charging,the + and - is showing short circuit GOODNESS Nokia Hardware & Hardware Repair 4 06-29-2006 09:36
T28 don`t turn on. Short circuit. Where? barvik Sony Ericsson Hardware Repair 3 10-23-2002 10:43
Page generated in 0.24989 seconds with 10 queries
