Only MAX232 ??? hi there i found that all cables work using a MAX ic This IC is not avilable in my country is there an equivalent that works i would be gratefull for any answers . Thank you in advance MY FRIENDS AMIGO |
Hi Amigo I use a HIN232CP ic Or you can try ICL232CPE. This works for me Regards Remco |
Hi. I am in the Philippines Here, only MAX232 is available. I have successfully built myself a dual mode cables. I have made from 2 circuit dessigns allready any both failed in NDS but they are working with other softwares. If you have made a MAX232 based cable to work with NDS, please give ne a copy of the diagram. Thanks. |
Any TTL <--->RS232 converter/shifter will work , except for some specifics schems who need -10v from pin 6 of MAX232. In my country, Burkina Faso , West Africa, the only available is the MAX233. It works all the time , easy to use ( don't need capacitors and so...). I think these chips are all like XXX232yy .. Good luck. The only cāble , you can make without MAX232 is the BDM module for Motorola , with a lot of 74LSXX ! |
First i'd like to thank all my frinds who sent replys I need some thing that is not XXX232XX or so what waiting for mor replys Keep Going for WildSwan what is your email ? Forgot to till you that LTC1386 ,LT1180 , LT1181 also works and also unavilable Need some help please Thank you All AMIGO [This message has been edited by AMIGO (edited 12 April 2000).] |
Also LTC1386 ,LT1180 works and also not avilable |
What country do you live in? Can't you just order it from another country? |
