Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section. |
| | #1 (permalink) |
| Junior Member ![]() Join Date: Mar 2000
Member: 1073 Status: Offline Thanks: 0
| hi there i found that all cables work using a MAX ic This IC is not avilable in my country is there an equivalent that works i would be gratefull for any answers . Thank you in advance MY FRIENDS AMIGO |
| | #3 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 1999 Location: Metro Manila
Member: 827 Status: Offline Thanks: 0
| Hi. I am in the Philippines Here, only MAX232 is available. I have successfully built myself a dual mode cables. I have made from 2 circuit dessigns allready any both failed in NDS but they are working with other softwares. If you have made a MAX232 based cable to work with NDS, please give ne a copy of the diagram. Thanks. |
| | #4 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 1999 Location: Burkina-Faso
Member: 318 Status: Offline Thanks: 0
| Any TTL <--->RS232 converter/shifter will work , except for some specifics schems who need -10v from pin 6 of MAX232. In my country, Burkina Faso , West Africa, the only available is the MAX233. It works all the time , easy to use ( don't need capacitors and so...). I think these chips are all like XXX232yy .. Good luck. The only cāble , you can make without MAX232 is the BDM module for Motorola , with a lot of 74LSXX ! |
| | #5 (permalink) |
| First i'd like to thank all my frinds who sent replys I need some thing that is not XXX232XX or so what waiting for mor replys Keep Going for WildSwan what is your email ? Forgot to till you that LTC1386 ,LT1180 , LT1181 also works and also unavilable Need some help please Thank you All AMIGO [This message has been edited by AMIGO (edited 12 April 2000).] |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| modify from max232 to max3232 | welly2000 | Off Topic Zone | 5 | 07-28-2003 13:21 |
| gx10 schematics using max232 | makona | Sharp | 4 | 04-17-2003 20:10 |
| COM port cable for V60/V66/V70 use MAX232 ,work with victor software. | Quang Thao | P2k Series | 14 | 11-01-2002 23:24 |
| All Motorola unlocking box max232 ?! | SoftSkiner | GSM Programming & Reverse Engineering | 1 | 07-16-2002 17:59 |
| What cable work with T205 - on MAX207 or 2 MAX232 | maks | ODM (Original Design Manufacturing) | 6 | 12-26-2001 21:55 |
