Old 04-20-2007, 18:00   #1 (permalink)
Member: 142994
Thanks Meter: 66
6270 Lcd
hi...
6270 water damage... dark blue display...but not white...LED light ok...but not Back Light...thts only Blank...any solution plz
thnx
Old 04-20-2007, 19:08   #2 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 1,350
normaly this fault came from lcd so change lcd first
let me know then
post result
Old 04-20-2007, 20:02   #3 (permalink)
Member: 142994
Thanks Meter: 66
let me know then
post result
yes i forgot to inform...i have already changed LCD & Flex
Old 04-21-2007, 10:28   #4 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
then you should change two esd filters near display connector of main board
post result
Old 04-22-2007, 18:44   #5 (permalink)
Member: 142994
Thanks Meter: 66
post result
thnx for reply dear
i changed..tht both ESD filters...but problem still there
Old 04-23-2007, 10:11   #6 (permalink)
Moderator
.:SARCAR:.'s Avatar
Member: 322206
Thanks Meter: 1,350
15 days ago I have repaired 2 sets with same fault like yours , repair 1 set change lcd with original one & 2nd set by changing esd filters so try with original lcd
post result
Old 07-25-2007, 14:59   #7 (permalink)
aui
Member: 87762
Thanks Meter: 30
i have same problem , thank
Old 07-25-2007, 15:08   #8 (permalink)
Member: 333035
Thanks Meter: 2
Hi mate, if no broken lines, check the "BLACK IC (5 pins)" below BLUETOOTH MODULE... Measure the capacitor...
U got the picture
Ps post result
The Following User Says Thank You to alexlow05 For This Useful Post:
6270 LCD Problem shok9992000@yah Nokia Hardware & Hardware Repair 8 04-20-2010 16:41
6270 lcd no light patrik.b Nokia Hardware & Hardware Repair 11 12-27-2008 14:51
6270 lcd light problem GSMTURBO Nokia Hardware & Hardware Repair 0 05-08-2008 19:32
6270 lcd light PROBLEM ansari123 Nokia Hardware & Hardware Repair 0 05-07-2008 09:11
need nokia 6270 lcd jennygdgsm Wanted Products 2 05-10-2007 05:22
Page generated in 0.20536 seconds with 9 queries
