Old 12-07-2006, 11:08   #1 (permalink)
Member: 275946
Thanks Meter: 8
Thumbs down phone startup failed,
hi,frnds i have set nokia 7610, when starts,show ,startup fail contact retailer, i was formatte set using * 3 &call button , set gets full formatte but same result, then i reball uem ,but no result,any body what the hell is going on ,plz reply
The Following 2 Users Say Thank You to sandeepmtc For This Useful Post:
Old 12-07-2006, 14:35   #2 (permalink)
Crazy Poster
Member: 170056
Thanks Meter: 23
hello , I whant to gife you if you possed a n box or a tornado box go where you see wrhit user setting all will be ok.
The Following 2 Users Say Thank You to Mohamadmohamad For This Useful Post:
Old 12-08-2006, 04:10   #3 (permalink)
GSM_BLUE's Avatar
Member: 356202
Thanks Meter: 46
hey buddy dont be afraid to click the search button..... it will help you a lot... theres a lot of threads for this solution......
br
The Following User Says Thank You to GSM_BLUE For This Useful Post:
Old 12-08-2006, 04:40   #4 (permalink)
Member: 382968
Thanks Meter: 7
try to flash sir
full erase first before you flash.
The Following User Says Thank You to notz_gsm For This Useful Post:
Old 12-08-2006, 07:32   #5 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
its not a uem problem,change start up ic ............alll fine
The Following User Says Thank You to puneet14884 For This Useful Post:
Old 12-09-2006, 12:14   #6 (permalink)
Member: 276297
Thanks Meter: 2
just format user area your fone will ok 100% tested
The Following User Says Thank You to navid787 For This Useful Post:
Old 12-20-2006, 18:04   #7 (permalink)
Member: 393725
Sonork: 100.1602458
Thanks Meter: 81
change flash ic415 and ur set is ok
The Following 2 Users Say Thank You to sunnychopra For This Useful Post:
succes full repair phone startup failed and security test failed jagdish puri MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-12-2010 14:17
flashing e51 on usb.phone flashing complete but show phone startup failed ravin j tejura Universalbox 1 12-14-2009 14:43
credits lost and now phone is on phone startup failed vikas chadha Universalbox 9 03-18-2009 12:29
7650: Phone startup failed. Contact the retailer. Greatgonzo Griffin 7 06-24-2004 11:39
7650 wont come out from phone startup failed Alinus Griffin 4 08-27-2003 22:46
Page generated in 0.21520 seconds with 9 queries
