07-21-2004, 20:33 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Age: 56
Member: 52884 Status: Offline Thanks Meter: 13 | placing bga ics |
07-22-2004, 05:50 | #2 (permalink) |
Insane Poster Join Date: Jul 2004 Location: Inside My Pc
Member: 72392 Status: Offline Thanks Meter: 3 | i guess you're very ready to place your new BGA ic on the board. No need to remove the silver dots or you'll likely to end up........deadset. Whats with a board that look as if its a virgin? Just clean up the flux right after placing the ic... |
07-22-2004, 07:42 | #3 (permalink) |
No Life Poster Join Date: Jun 2002 Location: CTSA Age: 46
Member: 12660 Status: Offline Thanks Meter: 7 | @ buschell Like a virgin? do you like young girls? The "silver dots" are all you need when using "desoldering wire" Solder wick you want to remove the solder balls remaining then clean pcb with a flux cleaner then check all pads are intact then you are ready to replace the uBga just use a little flux then place ubga, It doesn't have to be 100% lined up as it will move into posistion when solderballs melt but don't expect that to work when the uBga is sitting 45% WBR D. |
how to reball BGA ics? | hany elsaghir f | Nokia Hardware & Hardware Repair | 2 | 01-22-2007 16:13 |
Help Needed-bga Ics | jamohaki | Nokia Hardware & Hardware Repair | 5 | 08-08-2005 11:46 |
checking BGA ics | buschell | Nokia Hardware & Hardware Repair | 0 | 09-11-2004 20:04 |
bga ics | Black-Axe | Nokia Hardware & Hardware Repair | 1 | 12-04-2002 05:38 |
How to remove glue around BGA ICs on Nokia? | dimka | Nokia Hardware & Hardware Repair | 12 | 07-21-2002 19:59 |
