03-26-2007, 04:45 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: INDIA
Member: 350571 Status: Offline Thanks Meter: 920 | please help 1100 Erasing Error: 10, at: 0x01170000-0x0117FFFF, it shows follwing msg, 1st Boot Ok, DCT4, UPP: 1201 Fl0: 0x01000000-0x01FFFFFF,B582B190, Algorithm: u_intel.fia, Ver: 4.55.0 Algorithm Ok, MSID: 840CD6C3DB163141CFD07231FA Decoded MSID: 3E4EBAE9-000EB0BD-A8000000 Encoded FAID: FB813399-122F324F-8AC19D6B Erasing: 0x01170000-0x0117FFFF ... Erasing Error: 10, at: 0x01170000-0x0117FFFF, 940207, Time: 00:00 Process Failed, Repowering Mobile any good solution please |
03-26-2007, 05:12 | #3 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Wish Phone
Member: 331835 Status: Offline Thanks Meter: 64 | yeah agree with bro emil ,if not work.maybe you must update your FIA file or check your cable...if it's not work too ,hmmm Flash IC problem... Greet,.. Willy |
03-26-2007, 05:32 | #7 (permalink) |
No Life Poster Join Date: Mar 2007 Location: GREENHILLS
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | hi! guy's if you change the flash IC is u need 2 change also the UEM, or you make pacht the imei number of UEM coz the RPL is rumbled. good luck... |
03-26-2007, 07:35 | #10 (permalink) |
Member: 467922 Status: Offline Sonork: 100.1612115 Thanks Meter: 215 | guy's try this...option check the batt. terminal, then after post the result pls rate this thread nokia 1100 Last edited by DEADBOOT; 03-26-2007 at 08:04. |
03-26-2007, 08:42 | #15 (permalink) |
Freak Poster Join Date: Oct 2006 Location: Ampang,Kuala Lumpur,Malaysia Age: 54
Member: 363434 Status: Offline Thanks Meter: 4 | @ Sree Krishna If U R facing the fault "Erasing Error 10" Then it is 100000% flash IC fault, and U can change it but not easily. for changing this IC U have to try may be many times . and after replacing every time U have to try flash the fon. If fon becomes power on and showes IMEI ????????????4 then it is not flash ic fault . it is UEM IC fault. in this case don't waist your time any more to repair this fon.cos it is not easy and affordable to change new UEM and then write RPL. |
1200 Erasing Error: 4, at: 0x01100000-0x0111FFFF, Time: 03:18 | huong2 | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 02-12-2010 09:23 |
Erasing Error: 4, at: 0x01380000-0x0139FFFF | raul25_07 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 11-15-2009 19:45 |
Erasing Error: 10, at: 0x01000000-0x0100FFFF, 940207 | nost | n-Box | 9 | 12-17-2007 17:08 |
faild to flash 3 piece of 6230i Erasing Error: 10, at: 0x00000000-0x0000FFFF, 940207 | excel service | UFS2 + UFS3-Tornadoflasher | 7 | 04-21-2006 04:50 |
1100 Erasing Error: 10, at: 0x01170000-0x0117FFFF, 940101, | baraka42 | Twisterflasher | 2 | 04-09-2006 11:03 |
