please help on nokia 3310 complete flashing of contact service PLEASE HELP on this problem i flash many sets coba serial no is ok every thing is ok but set is still in the same please give me the solution and trick about this big problem |
please chek the above threat |
what software you are using use geoflsher best for dct3 |
3310 contact service Jaf And UFS3 i have these tow software |
may be it's hardware fault...try change cobba ic.............. |
no this is not hardware coba serial no is ok |
use Search Button............... |
i think u flash it with ufs3. if yes than change its cpu |
i was have problem like yours.. just change your CCONT.. :D:D:D |
DCT3 contact service Quote:
3310 Contact service 1 Attachment(s) I am here sending a software; with that you can know why set is showing contact service. 1 Open software 2 Press read (Some time it says phone init. failed, press yes and again press read) 3 When it reads mobile, now press RUN ; New window will open & there you will know the reason why it is showing contact service. 4 Also note IMEI no. while you read, if it is"000000000000000" or "656565656565656" then you have to flash the set.(Flash with Geo Flash) |
