Old 05-21-2006, 12:12   #1 (permalink)
Member: 63119
Thanks Meter: 2
pls help me i'am in a big trouble
hi friends
i had got a nokia 6600, it was displaying nokia and after some sec goes off , but while flashing it with ufs-3, i got blank display and phone goes off after 15 sec, i had also done full erasing and after that i flash muc+ppm but the problem is same,
please help me
regards
Old 05-21-2006, 14:33   #2 (permalink)
Member: 249504
Thanks Meter: 2
did you format user area? if you did this, your problem is in one or more of the flashes
Old 05-22-2006, 01:39   #3 (permalink)
wei
Member: 277791
hey guys i think u o should on line 4 discus problem
Old 08-26-2006, 11:30   #4 (permalink)
manyosa's Avatar
Member: 271974
Thanks Meter: 97
you were suporse to format the phone.so erase and reflash with latest flash file,write pm and format user area.
Old 08-27-2006, 05:51   #5 (permalink)
Member: 223959
Thanks Meter: 8
flash ur phone with latest version first then format ur phone manually
this will help
Old 08-27-2006, 06:08   #6 (permalink)
Member: 64823
Thanks Meter: 439
its too EASY problem try a good search am sure ull find a solution ... anyway try this:
Erase phone...full
write cceeprom both mcu+ppm
write good flash file...
Voila.... and i ask you to use a Griffin Box...
Old 08-28-2006, 10:29   #7 (permalink)
adampurhawks's Avatar
Member: 258154
Thanks Meter: 319
Hey Mate Just Use the way ZAKIYYBOSS Says and after flashing just "Format User Area " and it will be OK..
Regards
Adampur Hawks
pls help me am in haste infinity team balbal Infinity-Box 1 05-29-2009 21:59
its regarding Communicater 9210i.pls help me,i m in trouble shinojmahe Nokia Hardware & Hardware Repair 3 03-27-2006 18:23
Pls. help me.. thanks in advance!! boldface Nokia Multimedia 1 05-20-2005 05:42
Pls.help me have a big problem!!!!! Sandy x1x to x45/x50 3 04-26-2001 18:37
Page generated in 0.17047 seconds with 10 queries
