05-23-2009, 14:47 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | Pls. Help-nokia n70-dead showing the following problem I have got a dead N70-1. When I check it with JAF then the following message is being shown : JAF SHOWS THE FOLLOWING MESSAGE : ========================== Asic ID: 17100701 Asic Mode ID: 00 Asic Public ID: 8A82EAA3F1AE09D7FB36D0F1E366D60D21AA0D08 HASH: 2C05369F57CC3C4CF9E783E83D9B512B00000000 ROM ID: AB5E4ADB27A06946 CMT Boot Data: Asic ID: 000000010000022600010006000C192101002200 Asic Mode ID: 00 Asic EM ID: 00000353 Asic Public ID: 15700206537B5A51E5A0BD7091F128476AA11ABE HASH: E9EFF4BFAA5393217CA6B17755FC3E1400000000 ROM ID: F28A211FCEA7B19D CMT Boot File: C:\Program Files\ODEON\JAF\Flash\UFS\rap3gv2_2nd.fg Loader version: 01.10.02 -> Revision: 0000 Patching CMT boot step2... CMT Boot Ready No flash ids reported... Error in cmt get id... UFS-3 SHOWING THE FOLLOWING MESSAGE : ============================= 1ST BOOT : C0,0C [Rm-84] [2.0.8.4] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 8A82EAA3F1AE09D7FB36D0F1E366D60D21AA0D08 OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 15700206537B5A51E5A0BD7091F128476AA11ABE RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.11.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0 00000090: 00 00 .. ERR: APE 2ND Boot FLB1_MSG_C2: 00000400000000B172 APE 2ND CONF: Rebooting Mobile Is this COMBO FLASH CHIP Problem ? Thanks in advance, Regards, amit123 |
05-23-2009, 21:43 | #5 (permalink) |
Product Manager Join Date: Sep 2003 Location: Indonesia Age: 45
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,155 | check vddr ape for comboflash first .. it must be 1.8v if its no voltage.. jumper it from vio.... if voltage ok.... reball or change Comboflash br |
The Following User Says Thank You to Rizal Arsyad Dini For This Useful Post: |
05-23-2009, 22:32 | #7 (permalink) | |
Insane Poster Join Date: Aug 2008 Location: IRAN Age: 40
Member: 838770 Status: Offline Thanks Meter: 7 | Quote:
tested and 100%worke. | |
The Following User Says Thank You to mehdi1978 For This Useful Post: |
05-24-2009, 14:44 | #10 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Hello Mates, Is this the tasted solution ? Pls. share your thoughts. Regards, amit123 |
The Following User Says Thank You to amit123 For This Useful Post: |
05-24-2009, 23:41 | #11 (permalink) |
Member: 39251 Status: Offline Sonork: 100.1618715 Thanks Meter: 6,155 | this will solve yout problem if... smps clock to reslult vcorea is damaged... and if ape regulator for result vddr ape is damaged.... if still same.. change combo flash br |
The Following 2 Users Say Thank You to Rizal Arsyad Dini For This Useful Post: |
05-26-2009, 13:25 | #12 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Hello ichal_spy, I have checked the required voltage of 1.8 Volt. The voltage was ok. So, I reballed the COMBO IC . After reballing the COMBO IC it shows the following message in UFS-3. 1ST BOOT : C0,0C [Rm-84] [2.0.8.4] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 8A82EAA3F1AE09D7FB36D0F1E366D60D21AA0D08 OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 15700206537B5A51E5A0BD7091F128476AA11ABE RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.11.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK IMAGE : RM84_50737301.C0 CMT NOR Erase Area: 0x00000000-0052B515 CMT NOR Erase Area: 0x006A0000-006BFFFF CMT NOR Erase Area: 0x006DF000-006EFFFF CMT NOR Erase Area: 0x00700000-007EFFFF CMT FLASH ERASE OK, Time: 00:02 Written: 7 Certificate(s) CMT FLASH WRITE OK, Time: 00:45 1ST BOOT : C0,0C [Rm-84] [2.0.8.4] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 8A82EAA3F1AE09D7FB36D0F1E366D60D21AA0D08 OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002200 EM 1 ID : 00000232 EM 2 ID : 00000353 RAPx PBID : 15700206537B5A51E5A0BD7091F128476AA11ABE RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FCEA7B19D CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.11.0 CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK APE 2ND Bt: helen3_2nd.fg, Ver: 1.31.0 00000090: 00 00 .. ERR: APE 2ND Boot FLB1_MSG_C2: 00000400000000B172 APE 2ND CONF: IMAGE : RM84_50737301.C0 Process Failed, Repowering Mobile After "Check" I went for flashing by clicking on the "WRITE FLASH" button, it started showing the message as "DATA BLK ERROR,.." , I kept on clicking on the "YES" button. Thus CMT FLASHING WAS OK.But after that shown the last 2 lines message on the above. Now tell me should I try to pick up the RAP UPP & FLASH IC Now? Advance thanks, amit123 |
The Following 2 Users Say Thank You to amit123 For This Useful Post: |
05-26-2009, 13:28 | #13 (permalink) |
05-26-2009, 16:09 | #14 (permalink) |
Insane Poster Join Date: Apr 2008
Member: 741725 Status: Offline Thanks Meter: 13 | I have the same problem in the device 6680 Help me to solve it 1ST BOOT : C0,0C [Rm-36] [2.0.8.4] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 7C7B1D51DD7E96389884E3A901966D162CD56DA0 OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002100 EM 1 ID : 00000232 EM 2 ID : 00000341 RAPx PBID : 06600115D1C04F57AFB63FC6D0CE76EA803D00AC RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FAC901AEE CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT FLID0 : 00EC22FA-00000011, Sam K8S6415ETA CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5 CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D CMT VPP : Internal DUAL LINE : False CMT ALG Boot OK IMAGE : RM36_5.050440_B5.C0R CMT NOR Erase Area: 0x00000000-00509309 CMT NOR Erase Area: 0x006A0000-006BFFFF CMT NOR Erase Area: 0x006DF000-006EFFFF CMT NOR Erase Area: 0x00700000-007EFFFF CMT FLASH ERASE OK, Time: 00:46 Written: 7 Certificate(s) CMT FLASH WRITE OK, Time: 00:31 1ST BOOT : C0,0C [Rm-36] [2.0.8.4] OMAP ID : 17100701 OMAP MODE : 00 OMAP PBID : 7C7B1D51DD7E96389884E3A901966D162CD56DA0 OMAP HASH : 2C05369F57CC3C4CF9E783E83D9B512B OMAP ROID : AB5E4ADB27A06946 RAPx ID : 000000010000022600010006000C192101002100 EM 1 ID : 00000232 EM 2 ID : 00000341 RAPx PBID : 06600115D1C04F57AFB63FC6D0CE76EA803D00AC RAPx MODE : 00 RAPx HASH : E9EFF4BFAA5393217CA6B17755FC3E14 RAPx ROID : F28A211FAC901AEE CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv2_2nd.fg, Ver: 1.21.0 CMT FLID0 : 00EC22FA-00000011, Sam K8S6415ETA CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5 CMT KSIG0 : 0F72BF9DE5D6711B3B1133EBCAB5914FA419C78D CMT VPP : Internal DUAL LINE : False CMT ALG Boot OK APE 2ND Bt: helen3_2nd.fg, Ver: 1.35.0 00000000: 04 00 00 00 00 B1 72 ......r ERR: APE 2ND Boot FLB_MSG_C2: APE 2ND CONF No Info IMAGE : RM36_5.050440_B5.C0R Process Failed, Repowering Mobile |
The Following User Says Thank You to bisso cat For This Useful Post: |
05-26-2009, 16:53 | #15 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: Bangladesh Age: 38
Member: 1003058 Status: Offline Sonork: 100.1589274/mahbubalfa Thanks Meter: 26,433 | Quote:
100% ok... resalt post here... | |
The Following User Says Thank You to mahbubalfa For This Useful Post: |
.: Nokia N70 Dead Pls Help :. | billal1050 | Nokia Hardware & Hardware Repair | 2 | 03-17-2009 10:53 |
Can any one help nokia n70 error show what is the reasons? | debmobile | Nokia Hardware & Hardware Repair | 2 | 10-04-2008 19:27 |
Nokia N70 Dead Pls Help! | ofencemira | Nokia Hardware & Hardware Repair | 1 | 03-25-2008 21:08 |
ok friends what about the following problem | jasim | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-03-2002 21:53 |
