04-06-2013, 14:06 | #1 (permalink) |
No Life Poster Join Date: Apr 2011 Location: kerala
Member: 1550704 Status: Offline Sonork: 100.1644808 Thanks Meter: 248 | pls helpe me its urjant 2700c pls....... net is oppen the mobile the application instaling time the error will display hls helpe me (certificate not on phone or sim error 2700c) |
04-08-2013, 06:25 | #7 (permalink) |
Member: 1550704 Status: Offline Sonork: 100.1644808 Thanks Meter: 248 | my problem note solved flashing with atf box new vershan same problem any application instal the error will display.... (certificate not on phone or sim error ) pls give me more solution... |
04-08-2013, 13:21 | #8 (permalink) | |
No Life Poster Join Date: Feb 2012 Location: kanpur
Member: 1722956 Status: Offline Sonork: mybestfriend.adeel Thanks Meter: 305 | Quote:
1- back up your set from mx key first 2- erase it 3- flash it with atf 4- write rpl <bace up> from mx key sure problem solved dont forgete to post result | |
04-08-2013, 20:04 | #9 (permalink) | |
Member: 1550704 Status: Offline Sonork: 100.1644808 Thanks Meter: 248 | Quote:
thanks for the replay i will try with erase the mobile mx box the error display....... i think the flash memory location is damaged.......... | |
