01-06-2012, 21:49 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: KOLKATA Age: 51
Member: 102582 Status: Offline Thanks Meter: 72 | pls. uplod the video of fixing Nokia 5130 Keypad IC.. You will definitely agree with me that changing Keypad IC of Nokia 5130 / 7210c is very very tough because in most of the occasion, you will not be able to fix it up in first time. It takes at least 4/5 IC's to be replaced. Only then you will get success. So, I would request you to pls. uplod the video of fixing Nokia 5130 Keypad IC.. Advance thanks to all, |
01-07-2012, 09:44 | #2 (permalink) |
Member: 102582 Status: Offline Thanks Meter: 72 | Problem mainly comes at the time of removing solders from the PCB Keypad Point i.e. under the IC? If I use De-soldering Wick, there is a possibility to distort the connecting point under the Keypad ic. How to clean this solder and fix it up in one shot? |
01-07-2012, 10:19 | #3 (permalink) | |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Quote:
just clean the area , and take your solder iron and move it around the points with a bit of solder , you'll see the points become clean and almost flat. after all points are the same just clean and replace the ic , give it a bit of heating to stick it in place , then reheat with more heat and fun. good luck | |
The Following User Says Thank You to TRABEL For This Useful Post: |
01-08-2012, 21:56 | #7 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
i changed hundreds, even first changed was at first try working. it's all in your hands - you "have it" or not have it, that kind of skill it's Z2401 ... there is no upper or lower ic, check SCHEMATICS HERE and you will know which one. b.r. ALex | |
The Following User Says Thank You to Brka For This Useful Post: |
01-09-2012, 00:05 | #8 (permalink) |
Freak Poster Join Date: Dec 2011 Location: Siberia
Member: 1708008 Status: Offline Thanks Meter: 46 | Absolutely precisely.There are no upper or lower ic .There are no small and big ic. There are item number of component. Open the schematics, in it all answers. And in services manuals 3-4 level (SM_L3_4)there is an algorithm of repair on each malfunction. Silly to repair phone on color pictures. If ic it is badly soldered, it is necessary to increase temperature and soldering time. |
