04-30-2007, 17:49 | #1 (permalink) |
Junior Member Join Date: Dec 2006
Member: 418896 Status: Offline Thanks Meter: 0 | Plz help me how i can solder the 2600 sim Ic (because they are very very small) Hi I have a 2600,that show insert sim. I want to connect its IC sim base with Raj Archit method but because of its tiny base I can,t do this. Please tell me what is your soldering method about this base with a very very small diagram. Best regard Arash-Iran |
05-01-2007, 21:22 | #6 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 461058 Status: Offline Thanks Meter: 8 | -Remove the wrong ic and the tin with a fluxed solder wick -Put properly the ic right at its place -Heat "slowly slowly" once the tin balls'll start to melt Please Try to set your heater to get it hot enough and ****ing on quite to do this ! Good Luck Jack |
05-03-2007, 07:19 | #7 (permalink) |
Freak Poster Join Date: Sep 2006 Location: INDIA Age: 48
Member: 350948 Status: Offline Thanks Meter: 32 | First u have remove old IC simply by giving heat with flux,also note the mark of ic,then replace new one ic,remember making of jumper is very difficult because u can break PCB print of sim IC,Good Luck |
05-03-2007, 11:54 | #11 (permalink) | |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | This Time The Better Option For U Fix The New One Ic With Ur Smd .and For Practicing Take A Dead Board.after Some Time U Can Easliy Use Wire For Jumpering Where It Necessary. Quote:
plz help me if you can | med26 | Sony Ericsson | 1 | 02-28-2010 15:06 |
plz help me how can unfreez samsung c5510 | goldenploto | Z3X-Team Products | 19 | 02-24-2010 15:34 |
LG VX9100, can someone help me how to take out the personal lock code | mymiela0419 | Various CDMA/TDMA Cell Phones | 0 | 06-16-2009 15:00 |
plz help me how to unlock Orange TR1 | qayyoom1 | Infinity-Box | 7 | 07-07-2007 19:49 |
Helo All,Pls help me how I can reset my X-6 to factory setting | azizrana | ARM9 BASED M62 / M62+ | 0 | 04-15-2005 17:27 |
