07-16-2013, 16:21 | #1 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1127257 Status: Offline Thanks Meter: 5 | Plz Help ...Nokia 101 Dead.... Flash File Checksum Verification 16:24:23 : ================================================== ==== 16:24:23 : rm769_007.200: CHECKSUM PASSED 16:24:23 : rm769_007.20mg: CHECKSUM PASSED 16:24:23 : rm7690_nai07.20mg_nlt: CHECKSUM PASSED 16:24:23 : ================================================== ==== 16:24:23 : Verification Done... 16:24:25 : 16:24:25 : Booting Phone... 16:24:25 : VBATT Powering Down <<<< 16:24:27 : VBATT Powering Up >>>> 16:24:27 : SET VCCIO Level Done 16:24:27 : SET BSI Load Done 16:24:28 : 16:24:28 : Booting Phone... 16:24:28 : CPU ID Response: A200341100 16:24:28 : CPU Type: XG110 2.1B 16:24:28 : Phone Booted after 2 attempts... 16:24:28 : 16:24:28 : ************************************************** **** 16:24:28 : TIME STARTS HERE 16:24:28 : ************************************************** **** 16:24:28 : 16:24:28 : 16:24:28 : Sending PBL 19456 bytes... 16:24:28 : PBL Successfully Sent... 16:24:28 : 16:24:28 : Sending SBL 65024 bytes... 16:24:29 : SBL Successfully Sent... 16:24:29 : 16:24:29 : Flash Chip Manufacturer: STMicroelectronics 16:24:29 : Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR 16:24:29 : Extended Information: Multiple Bank / Burst / 1.8v 16:24:29 : 16:24:29 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.200 16:24:29 : 16:24:29 : FIRMWARE Image Found... 16:24:29 : Number of Sections: 03 16:24:29 : FIRMWARE Certificate Block Sent Successfully... 16:24:29 : Processing Section 01 of 03 16:24:29 : FIRMWARE Erase Block: 0x00000000~0x0001FFFE 16:24:29 : Start Erasing... 16:24:29 : Erasing Please Wait... 16:24:30 : Block Erase Done... 16:24:30 : Preparing Data Blocks... 16:24:30 : Data Size: 24576 bytes 16:24:30 : Data Checksum: F5BE 16:24:30 : Uploading Data Blocks to phone... 16:24:31 : FIRMWARE Data Blocks uploaded to phone... 16:24:31 : Processing Section 02 of 03 16:24:31 : FIRMWARE Erase Block: 0x00800000~0x00BFFFFE 16:24:31 : Start Erasing... 16:24:31 : Erasing Please Wait... 16:24:34 : Block Erase Done... 16:24:34 : Preparing Data Blocks... 16:24:34 : Data Size: 4128768 bytes 16:24:34 : Data Checksum: BFB7 16:24:34 : Uploading Data Blocks to phone... 16:25:55 : FIRMWARE Data Blocks uploaded to phone... 16:25:55 : Processing Section 03 of 03 16:25:55 : FIRMWARE Erase Block: 0x00C5D000~0x00E5FFFE 16:25:55 : Start Erasing... 16:25:55 : Erasing Please Wait... 16:26:15 : Block Erase Done... 16:26:15 : Preparing Data Blocks... 16:26:15 : Data Size: 1697536 bytes 16:26:15 : Data Checksum: 2B05 16:26:15 : Uploading Data Blocks to phone... 16:26:35 : FIRMWARE Data Blocks uploaded to phone... 16:26:35 : Start Data Verification... (Please wait) 16:26:39 : Data Verification Successful... 16:26:39 : 16:26:39 : 16:26:39 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm769_007.20mg 16:26:39 : 16:26:39 : PPM Image Found... 16:26:39 : Number of Sections: 01 16:26:39 : PPM Certificate Block Sent Successfully... 16:26:39 : Processing Section 01 of 01 16:26:39 : PPM Erase Block: 0x00100000~0x005FE17E 16:26:39 : Start Erasing... 16:26:39 : Erasing Please Wait... 16:27:27 : Block Erase Done... 16:27:27 : Preparing Data Blocks... 16:27:27 : Data Size: 5235072 bytes 16:27:27 : Data Checksum: 0C57 16:27:27 : Uploading Data Blocks to phone... 16:28:29 : PPM Data Blocks uploaded to phone... 16:28:29 : Start Data Verification... (Please wait) 16:28:29 : Data Verification Successful... 16:28:29 : 16:28:29 : 16:28:29 : Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-769\rm7690_nai07.20mg_nlt 16:28:29 : 16:28:29 : CONTENT Image Found... 16:28:29 : Number of Sections: 01 16:28:29 : CONTENT Certificate Block Sent Successfully... 16:28:29 : Processing Section 01 of 01 16:28:29 : CONTENT Erase Block: 0x00E60000~0x00F49FFE 16:28:29 : Start Erasing... 16:28:29 : Erasing Please Wait... 16:28:38 : Block Erase Done... 16:28:38 : Preparing Data Blocks... 16:28:39 : Data Size: 958464 bytes 16:28:39 : Data Checksum: 36AC 16:28:39 : Uploading Data Blocks to phone... 16:28:50 : CONTENT Data Blocks uploaded to phone... 16:28:50 : Start Data Verification... (Please wait) 16:28:50 : Data Verification Successful... 16:28:50 : 16:28:50 : 16:28:50 : Exit Flash Mode Done... 16:28:50 : Time Elapse : 00:04:22 16:28:54 : 16:28:54 : ************************************************** **** 16:28:54 : You must Factory Reset the phone to enable the 16:28:54 : ringtones and other customized settings to work 16:28:54 : ************************************************** **** 16:28:54 : 16:28:54 : 16:28:54 : Waiting For Phone to go Online... 16:28:54 : 16:28:54 : 5, 16:28:54 : 4, 16:28:54 : 3, 16:28:54 : 2, 16:28:54 : 1... 16:28:54 : 16:29:28 : ERROR : PHONE READ INFO FAILED 16:29:28 : 16:29:44 : Changing Phone Mode... 16:29:48 : ERROR: Phone did not Respond When Select normal mode show this error ERROR: Phone did not Respond and set power on.... but with bettry power not on.. |
08-10-2013, 18:16 | #5 (permalink) |
Insane Poster Join Date: Jul 2013 Location: Delhi, india
Member: 1979321 Status: Offline Sonork: 100.1647636 Thanks Meter: 10 | bro 1st heat power ic then flash again, if not flashed then chek lcd tracks(many times if lcd any track missing phone not flashed) after that try with change lcd post result press thanx if u like my post |
