09-29-2008, 16:56 | #4 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: My Computer
Member: 553178 Status: Offline Sonork: 100.1592454 Thanks Meter: 957 | Quote:
brother full erase and reflash and write pm mobile will be ok. if not try selftest and see result i think best box is ufs for selftest. and try to remove hardware fault witch given in selftest. if your problem solved by this post peass thanks button. Good Luck | |
04-06-2009, 05:04 | #5 (permalink) |
Crazy Poster Join Date: Feb 2007 Location: Takht bhai Mardan NWFP PAKISTA Age: 43
Member: 448854 Status: Offline Thanks Meter: 2 | HI every body i have a alway contect service specially in 1200 and1208 . i full erase and then flash with 5.71 through jaf and hwk but not sucess... does any one have the right sulotion.. |
04-06-2009, 05:59 | #6 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Inside of GsmhostinG
Member: 707582 Status: Offline Sonork: 100.1620432 Thanks Meter: 334 | BROTHER, use this metherds i hope the problem solved 1.erase and flash with latest version+write a good pm and unlock, factory reset also 2.clean PCB 3.just change LCD (use original LCD) 4.remove sim ic good luck br br, ..::BindAS::.. |
The Following User Says Thank You to VIBINDAS_INDIA For This Useful Post: |
04-06-2009, 06:11 | #10 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: M_B_Din-PK
Member: 950201 Status: Offline Thanks Meter: 1,928 | Quote:
if u have HWK perform self test... contact service appeirs due to several reasons.. if LCD not mached.. PM currupted.. sw version older .. or internal hardware fault.. first u unlock the set.......... i recover many 1650 and 1200 & 1208 by using this mathod.. if not work write good pm hope ur problem will solve | |
10-05-2009, 17:11 | #15 (permalink) |
No Life Poster Join Date: Oct 2007 Location: P A K I S T A N
Member: 604333 Status: Offline Sonork: 100.1590054 Thanks Meter: 1,845 | solution is here enjoy.....! http://forum.gsmhosting.com/vbb/show...70#post4906570 WBR Asif Shahzad G S M - D O C T O R .. T E A M |
The Following User Says Thank You to GSM-DOCTOR For This Useful Post: |
plz help me 6300 contact service | amer_a_82 | Nokia Base Band 5 ( BB-5 ) | 2 | 11-12-2009 12:37 |
1208 contect service after flash | ranem_111 | Nokia Hardware & Hardware Repair | 1 | 03-21-2009 19:48 |
1208 Contect Service | rijoo29 | Nokia Hardware & Hardware Repair | 3 | 04-09-2008 17:47 |
