05-14-2008, 13:33 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: Jordan Age: 46
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | is it possible to change new nokias mic. new digital mic. like in e90 e51. [microphone got poor quality]. phone is almost new, but unfortunately it got no warranty. BR Mansi |
05-14-2008, 13:46 | #3 (permalink) | |
Member: 8664 Status: Offline Sonork: 100.1573507 Thanks Meter: 56 | Quote:
i tested phone with headset, its working 100%, so its not a circuit problem. its only microphone fault, but i am not sure if it can be replaced, because its soldered on the phone's board, and even if you got new mic, you will damage it if you want to solder it with hot air. BR Mansi | |
04-04-2009, 02:58 | #8 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 43
Member: 2878 Status: Offline Thanks Meter: 9,123 | yes i have changed it many times. you need to desolder it, its sometimes very hard to desolder, you need hotair and solder iron to remove the rest. after this, clean the pcb and take some solder of the 4 contact bals. now heat the pcb with hotair and place in same time the new mic in place. use hotair and heat the mic only on the sides, not from upper side. i soldered in this way many times, and mic is working after this, not get demaged. br. hari |
The Following 3 Users Say Thank You to oOXTCOo For This Useful Post: |
04-04-2009, 15:57 | #9 (permalink) | |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Quote:
Right this is the solution but you need to have a good hand a good hot air the problem can happen whit 6 pin of E90 digital mic and this is very hard to do whit hot air, better to have an infrared machine otherwive you could have serious problems, so attention first to do any operation ensure that you are calm and concentrated. There is also another solution not very simply but for sure you can't destroy nothing, for 4 legs mic work perfect for 6 i don't try, need only to solder 4 bridge from mic to pad of main board you can use tiny wire for me in E90 work perfect. The engeener who make second revision of E90 whit mic at 6 pins probably it was drunk to concept this system and without to think that when would have been damaged they would have been several problems for change them.:-))) | |
04-04-2009, 17:55 | #10 (permalink) | |
No Life Poster Join Date: Nov 2004 Location: Indonesia
Member: 90761 Status: Offline Sonork: 1617079 Thanks Meter: 95 | Quote:
04-04-2009, 19:07 | #12 (permalink) |
Insane Poster Join Date: Feb 2004 Location: KSA, Al-jouf
Member: 53180 Status: Offline Thanks Meter: 11 | ive done this in e51 many times... all you have to do is to take out first the charging or ui connector, not that easy but it works.. use the hot air for pulling it out..why? - because you will resolder the mic with hot air direct to the board below not in the mic itself.. hope it will help... |
04-05-2009, 10:40 | #13 (permalink) | |
Member: 2878 Status: Offline Thanks Meter: 9,123 | Quote:
right, i tryed with ir station too, but mic dont worked after this. this is the reason way i use hotair. this jumper solution i trayed too, but i like it direct soldered JUST TEST WITH BROKEN BOARD BEFORE YOU GET TO A FULL WORKING E90, TO GET NEEDED SKILL AND YOU HAVE NO PROBLEM. br. hari | |
04-05-2009, 10:43 | #14 (permalink) | |
use metall tape to cover the connector, dont need to be removed. | |
Need To Know If Is It Possible To Change Languages For This ! | AE177 | HTC & PDA WM( With Touchscreen) | 2 | 06-21-2010 15:53 |
Is it possibly to change imei of motorola c168i [011++++] to [355+++++]?!?!? | Sau_Cell | Motorola Hardware Repair | 0 | 03-29-2009 11:27 |
is it possible to change imei to LG 8120 ? | cellularman | Cruiser Suite | 6 | 11-21-2006 08:52 |
Is It Possible To Change Imei Of Nokia 7710? | matrixgsm | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 11-02-2006 23:18 |
is it possible to change PF08107B to any other ? | VREDNYJ | Siemens Hardware Repair Area | 6 | 06-12-2004 16:49 |
