Old 10-23-2014, 13:32   #3046 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
[IMG]http://3.bp.********.com/-tNxZQDdXc_w/Ue4uY5H_hwI/AAAAAAAAA34/YwMyeEp4o2Q/s1600/20.jpg[/IMG]
Originally Posted by bogdan_meserias View Post
Thanks for your answers. Can you give me an example where to buy such wire or can you give me a link with this wire to see and buy? Thank you wery much again?
Old 10-23-2014, 13:36   #3047 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
you can buy from cellphone accessories wholesaler shop
Old 10-23-2014, 16:29   #3048 (permalink)
Member: 1822235
Sonork: Meseriasu80
I found wire fr coils. Diameter 0.1mm, 0.2mm, 0.3mm. What diameter you sai it is suitable? Is this kind of wire ok?
Old 10-24-2014, 11:36   #3049 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
diameter is like hair, as I told above.
it is insulated(coated) wire
Old 10-26-2014, 00:29   #3050 (permalink)
Member: 2280852
Nokia 515. Is it possible to replace the WCDMA radio receiver with another Nokia phone so I utilize the 850 MHz or 1900 MHz WCDMA bands in the states? Perhaps the Nokia 700 or the Nokia 6700?
Nokia 515 Frequency Bands - WCDMA network (3g): 900 MHz, 2100 MHz
Old 10-29-2014, 08:12   #3051 (permalink)
Member: 2282137
my nokia e72 running latest firmware switching off when in range or connecting or receiving call. working as usual without sim and in offline mode with sim. no other complaints but cant make or receive calls or even put in general mode from offline. reflashed the firmware but no use. hardware issue itself
Old 10-29-2014, 09:08   #3052 (permalink)
nafe2me's Avatar
Member: 977479
Sonork: 100.1638508
Thanks Meter: 795
I think, this problem is from network section
first change pa & then post your result....
The Following User Says Thank You to nafe2me For This Useful Post:
Old 10-29-2014, 10:44   #3053 (permalink)
Member: 2282137
rf pa or any other power amplifier. and is there seperate pa for gsm and wcdma. what are the other components to be checked for this complaint. thankx for ur time
Old 10-30-2014, 03:35   #3054 (permalink)
Member: 2282137
can we check if it is pa problem without replacing it using multimeter or anything else..plz reply
Old 10-30-2014, 04:49   #3055 (permalink)
Member: 879851
Thanks Meter: 16
Hi, nokia lumia model 520 RM-914 not starting properly its stuck on blue screen every time when i press start button.
Is there any solution for that please,i have only ASANSM box nothing else,so please guide here how can i repair it soon.Thanks in advance.
Old 10-30-2014, 23:51   #3056 (permalink)
Member: 1923273
Nokia 500 power off with Sim working normal without Sim pls help me brother
Old 10-31-2014, 09:02   #3057 (permalink)
Member: 398676
Nokia 210 PC connectivity
Dear,
I am unable to connect Nokia 210 with PC.
When connected to PC through Nokia PC Suit. It show ERROR "NOKA CONNECTED IN A NON-COMPATABLE USB MODE".
Please help how can i take back of my Contacts / messages and other from Phone.
Regards.
S.B. Pani
Old 11-01-2014, 10:39   #3058 (permalink)
Member: 2105475
Thanks Meter: 7
sir help me 3120 not send the message but fhe signal is high pls give me solution
Old 11-01-2014, 11:28   #3059 (permalink)
Member: 879851
Thanks Meter: 16
No any solution expected here total wastage of time.thnx
Old 11-01-2014, 11:38   #3060 (permalink)
Member: 2121304
Nokia 7230 white lcd
I have nokia 7230 it turns on with white lcd do you have any solution for this
Page generated in 0.22587 seconds with 11 queries
