Old 01-08-2011, 10:20   #16 (permalink)
Member: 850148
Thanks Meter: 36
bro check bsi line ....or remove battery connecter backside componunt..&bsi line componint.....100% solv ur prob...
thats basic bro, already did that..
also I reball UEM ic, still same..
maybe u have some tricks, or something to remove in motherboard
just like twin resistors, and if u have schematic diagram pls share..
thanks for your effort...
regards
Old 01-08-2011, 12:23   #17 (permalink)
RATHNAMOBILESS's Avatar
Member: 581178
Thanks Meter: 438
bro ur pcb 99% waterdamage so clean ur pcb with ultrasonic pcb cleaner.......
Old 01-08-2011, 14:35   #18 (permalink)
Crazy Poster
Member: 1484572
Thanks Meter: 13
Originally Posted by RATHNAMOBILESS View Post
wat mobil hist.....??????????
i dont understand u sir .what u want to say ?
Old 01-08-2011, 15:00   #19 (permalink)
Member: 581178
Thanks Meter: 438
wat is ur mobil history.....
Old 01-09-2011, 02:49   #20 (permalink)
Member: 850148
Thanks Meter: 36
I did sir, twice....
still....
Old 01-09-2011, 10:03   #21 (permalink)
Member: 883301
Sonork: 100
Thanks Meter: 12
i need help to solve memory in use in n97 32gb already i flash format the phone but still same condection. what to do?help me plz
Old 01-10-2011, 08:03   #22 (permalink)
Member: 581178
Thanks Meter: 438
The traditional method won’t work as the N97 doesn’t have the old keypad. After you’ve backed up your data onto memory card/pc/ovi, turn your phone off and simultaneously press these four buttons circled in red.
* Caps shift
* Space bar
* Delete button
* On button
You’ll know it’s worked when you see the initial set up screen, asking country of origin. I haven’t actually tried this, but I’ll be doing so when I return the trial N97.
after formet prob not solv try to rehot flash chip.bigest chip on the board..or reboll flash chip...
The Following 3 Users Say Thank You to RATHNAMOBILESS For This Useful Post:
Old 01-10-2011, 10:37   #23 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 2,771
can u give me rm-555 nokia n97-4 disemblly???????????????
Old 01-10-2011, 11:03   #24 (permalink)
Member: 1479917
Sonork: abbasfunkenho
nokia 2600c-2
hp can on but lcd no light..do i have to change the backlight ic? plz help?
Old 01-10-2011, 11:11   #25 (permalink)
saqi160's Avatar
Member: 780173
Sonork: 100.1594488
Thanks Meter: 912
hi to all brothers
i have nokia 2630 its problem camera not work
i on the camera its show only white display not show image
i wash the pcb and re hot ic but problem same
i remove the ic and make the jumps but same
any solution of its problem
advance thanks
Old 01-10-2011, 11:12   #26 (permalink)
Member: 775567
Sonork: tybsky
Thanks Meter: 59
nokia 2700c, 5130c and 7210c
nokia 2700c, 7210c and 5130c only shows nokia and white after power off. i change lateset ver of software, change kp & display ic clean pcb but phone is still how to slove this problem .
Old 01-10-2011, 11:25   #27 (permalink)
Member: 581178
Thanks Meter: 438
try tis........& post result...
File Type: jpg 2600c-2630 light modif ultimate solution.jpg (100.5 KB, 777 views)
Old 01-10-2011, 11:26   #28 (permalink)
Member: 634458
Thanks Meter: 21
give me solution nokia n73 wight light ............
Old 01-10-2011, 11:36   #29 (permalink)
Member: 581178
Thanks Meter: 438
N73 WHITE DISPLAY PROBLEM SOLUTION...............
1st check incoming outgoing..
try to flash or try this,,,,,,,
The Following 2 Users Say Thank You to RATHNAMOBILESS For This Useful Post:
Old 01-10-2011, 11:49   #30 (permalink)
Member: 690412
hello my freind ,, i have nokia 6500s after swittch it on , after 2 m the screen becoms white and nothing respond , sometimes it works when i make any call after 1m swittch off, and sometimes not turning on , i flash it with the latest version but still the same problem, could you please help me me to solve this problem,,,,,,,,,,,thank you very much
Page generated in 0.23437 seconds with 10 queries
