Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 11-11-2011, 12:23   #751 (permalink)
Dipankor-ctg's Avatar
Member: 1541551
Sonork: 100.1605718 {>>GsmAsha<<}
Originally Posted by srinivasan View Post
I have Nokia C2-01 which have network problem every time show no operator found.
try now
network Solution
The Following 2 Users Say Thank You to Dipankor-ctg For This Useful Post:
Old 11-11-2011, 17:07   #752 (permalink)
rezwan_jack's Avatar
Member: 776103
Sonork: 100.1596478
Nokia N-73 Network Problem need help
Set comes with PF short its getting Hot
I change pf but still same problem
The Following User Says Thank You to rezwan_jack For This Useful Post:
Old 11-12-2011, 06:10   #753 (permalink)
Member: 1541551
try now
Old 11-13-2011, 05:03   #754 (permalink)
Member: 765926
Sonork: mirfaisal81@yahoo.com
Red face nokia n95 dead while flashing with mx-box
i have a strange problem with n-95 RM-159. i had a problem with the maps application. i tried to flash it using mx-box with the latest version. at cnt it stopped and showed error. now i am not able to bus scan the handset nor flash it. my fbus cable is good but same response by fbus and usb cable as well. when i bus check it on fbus it just shows this log
Using device: HTI, FW ver: 00.24, SN: 0000BCBC
Connection status: UHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.19045(08-10-2011), Library ver: 1.0.0.12920(08-10-2011)
APE Data :
SYSTEM ASIC ID: 24200705 [OMAP2420 ver: 2.2]
ASIC MODE ID: 00
PUBLIC ID: EC95AE6B78231C26D432C7C6670D8BBA08133EA2
ROOT KEY HASH: BA8710A7E1CD5A2909B9A875DB27AA2400000000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006
400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
PUBLIC ID: 15E000096B9C0058694F172E6F4CEB3C0255D3D2
ASIC MODE ID: 00
ROOT KEY HASH:
CAEEBB65D3C48E6DC73B49DC5063A2EE
ROM ID: A8C1D6713E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 1.37.1 revision: 0.0 size: 0x3B80
Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
eBB5ProtocolType: OLD
Storage0: 0001 0035 - 0000 6921 [AMD S29NS128N,128 Mbits] type: FLASH,NOR, asic:CMT
Storage content: 0000 0000 0000 0000 0000 0000 0000 0000
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
TransmissionMode: 16Bit
Algorithm: RAPIDOv11_algo.fg [XSR 1.5] version: 1.40.0 revision: 0.0 size: 0x27520
CMT PAPUBKEYS HASH: 25129A39D9A3B031CA0124E1E90F5A17ED3EFC89
TransmissionMode: DDR&TX2
SecondaryBoot: omap2420_m1_2nd.fg [BB5] version: 1.41.0 revision: 0.0 size: 0x7C00
Supported Ids: 24200703, 24200704, 24200705, 24200706
I have been posting this problem since 1 month but no one has a solution. i am sure it's not a hardware problem.
when i connect it via usb the computer gives the sound only after long press and detects the phone does not flash. when i press flash via fbus it ***** the following log
APE Data :
ASIC MODE ID: 00
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE
loader not responding (00000000000000)
Total time for flashing process(boot+erase+write) was 21.750 s
Old 11-13-2011, 05:15   #755 (permalink)
Member: 765926
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
APE Data :
ASIC MODE ID: 00
CMT Data :
EM0 ID: 00000295
EM1 ID: 00000B22
ASIC MODE ID: 00
is it a problem with mx box version? i am confused. i tried it with turbo but it doesn't even chk the phone.
Old 11-13-2011, 09:08   #756 (permalink)
Member: 1493694
Sonork: 100.1623862
Red face
Originally Posted by RATHNAMOBILESS View Post
Post all nokia problems here.........
CMT 1ST Boot OK
CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
CMT FLID0 : 00EC2400-00008A31, Sam K8x1259ETF
CMT FLCNT : 00000000000000000000000000000000000000
CMT MCID0 : FFFF0000-00000000
CMT 2ND Boot OK
CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
CMT KSIG0 : C6B9354E81AC464DED33FC7B90295086150F4539
CMT VPP : Internal
DUAL LINE : True
CMT ALG Boot OK
IMAGE : rm635__10.65.mcusw
CMT NOR Erase Area: 0x00000000-000006BF
CMT NOR Erase Area: 0x000006C0-0001FFFF
CMT NOR Erase Area: 0x00040000-000BFFFF
CMT NOR Erase Area: 0x000C0000-0013FFFF
CMT NOR Erase Area: 0x00140000-0137FFFF
CMT NOR Erase Area: 0x01380000-0151FFFF
CMT FLASH ERASE OK, Time: 01:15
Written: 8 Certificate(s)
CMT FLASH WRITE OK, Time: 01:56
Chip SECTOR_SIZE: 128k
Warning, Must be Used 128Kb Sector_Size CNT File
CONVERSION: Already 128K Paged Source
IMAGE : rm635__10.65.image_t_blue_au
CMT NOR Erase Area: 0x01DC0000-0215FFFF
CMT NOR Erase Area: 0x02160000-03FBFFFF
CNT FLASH ERASE OK, Time: 00:37
CNT FLASH WRITE OK, Time: 00:55
IMAGE : rm635__10.65.ppm_t
CMT NOR Erase Area: 0x01520000-01DBFFFF
PPM FLASH ERASE OK, Time: 00:17
PPM FLASH WRITE OK, Time: 00:28
Flashing Completed, Rebooting Mobile
UI Defaults Failed
plz help urgent
Old 11-13-2011, 09:13   #757 (permalink)
Member: 977394
nokia N900 maemo flash after no imei ??? any solution ??
Old 11-13-2011, 14:01   #758 (permalink)
Member: 1537079
Hey, i dont get any hsdpa signle on my nokia c5-00.2, it shows 3.5g signle but not the 'H' in my case
Old 11-13-2011, 14:35   #759 (permalink)
Member: 1625723
Nokia 1202 lcd is not working.
Lcd is plane but lcd light is working.
Old 11-13-2011, 16:06   #760 (permalink)
Member: 1541551
now 1202 soluton
Nokia ALL Hardware-Repair My Solution now shared All member Bro Dipankor-ctg
Old 11-15-2011, 06:56   #761 (permalink)
Member: 1080951
Sonork: 100.1591728
nokia c1-00 network not pound
Old 11-16-2011, 07:15   #762 (permalink)
Member: 1186634
hi i recieve nn97 dead buut when i power on mobile is vibrate bu no , on
any solution you have plz tell me
thnks advance sir
Old 11-16-2011, 09:29   #763 (permalink)
Member: 1665430
pls i need scheme 5250 and short solution nokia 5250 remains touch water
Old 11-16-2011, 09:30   #764 (permalink)
Member: 1081162
Sonork: 123456789
i have nokia 3220
it is working 100% but it still a simple problem
when i press in keypad menu it is making off , i mean
when i touch with my finger keypad menu it's during off line
in the fact all keypad are all right and okay 100%
but keypad menu has this problem
Old 11-16-2011, 10:44   #765 (permalink)
dilshad_noori's Avatar
Member: 1293519
Sonork: 100.1596500
1208 hand free signal help
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
Page generated in 0.30423 seconds with 12 queries
