08-22-2006, 04:13 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Fast-Code™ MBKPHONE Ltd Age: 38
Member: 269035 Status: Offline Sonork: 1,618,0786 Thanks Meter: 301 | Post me all your 3100 & 6600 problems...! Last edited by khem; 08-22-2006 at 04:24. |
08-22-2006, 04:54 | #6 (permalink) |
Junior Member Join Date: Aug 2006
Member: 325669 Status: Offline Thanks Meter: 0 | In case of no network rebowl the uem hagar & cpu 100000000000% solved network problem. in case of contact service first change the software with latest ver. files second rebowl uem. |
08-22-2006, 06:16 | #7 (permalink) |
No Life Poster Join Date: Mar 2006 Location: In My CoMpaQ LaPtOP
Member: 249300 Status: Offline Sonork: 10101010 Thanks Meter: 569 | i have 3100 phone wwith contact service.I flashed with a newer verion but still contact verison.I heat the pcb but the problem is still same.When i put normal mode in ufs3 then phone getting on without any problem.If i put the battery n if switched on then contact service.How to solve this problem? |
The Following User Says Thank You to sharaz191 For This Useful Post: |
08-22-2006, 14:34 | #8 (permalink) |
Junior Member Join Date: Mar 2005 Age: 47
Member: 130846 Status: Offline Thanks Meter: 5 | 6600 flash ic details hi sir can u explain me the flash ram given in 6600 which ram responsible for which fault? along with pictures everytime flashing problem occured due to hardware the biggest question is to replace which flash ic first as 6600 has 4 ics |
09-05-2006, 19:44 | #10 (permalink) |
No Life Poster Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks Meter: 97 | 3120 flashing problem Hi.I have 3120 i can flash it completely but it cannot show local mode or do ulsetting i have already change different types of flash files but still .Help |
10-19-2006, 16:34 | #11 (permalink) |
No Life Poster Join Date: Jan 2006 Location: ONLY PRIVATE MSG
Member: 220932 Status: Offline Sonork: 100.1592154 Thanks Meter: 110 | hi. a 3100 when it on it show sim card registration failled,any network sim, ime ok.How to solve this problem? thanks. Last edited by soy; 10-19-2006 at 18:02. |
10-19-2006, 22:22 | #12 (permalink) | |
Freak Poster Join Date: Oct 2006
Member: 374225 Status: Offline Thanks Meter: 41 | Quote:
10-19-2006, 22:26 | #13 (permalink) | |
Fl1 <=> D316 Fl2 <=> D314 Fl3 <=> D315 bro if erasing process stop and flashing gets failed then see on which code u get error (fl0,fl1,fl2,fl3) the code u get error means that ic is corrupt nokia 6600 shows 1st Boot Ok, WD2, UPP: 0082 2nd Boot Error: 2 Platform: 6, Error Data: F3 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Process Failed, Repowering Mobile if u get this mess that means ur ram is corrupt | |
The Following User Says Thank You to pdapower For This Useful Post: |
Post me all your NETWORK PROBLEM... | khem | Nokia Repair Guide and FAQ | 963 | 04-07-2017 10:03 |
Post me all your problem (DCT-3 phones only) | blu angel | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 573 | 11-29-2010 18:56 |
post me all mt box problems | goherabbas | Nokia Hardware & Hardware Repair | 20 | 08-05-2010 12:34 |
