05-05-2007, 09:33 | #17 (permalink) |
Freak Poster Join Date: Mar 2005 Location: in the UK Age: 49
Member: 132117 Status: Offline Thanks Meter: 3 | @ sarojrkl - Has youur 2600 had any contact with liquid, Check for liquid damage. You can try changing the bottom connector. What program do you use? try and run a energy management calibration. This test basically tests everything to do with charging (BSI, VBAT etc etc) If problem is still there...Then its going to be UEM fault... @zultopo - It looks like you have 2 faults. Is there any liquid damage at all. Have you tried changing domesheet. If you have, then the fault with # button will be the filter. The charging fault, can be fuse, bottom connector etc. What have you changed on the charging problem.? @ H4ck - Did you upgrade the firmware version yourself, or did a local service centre do it? If you did it yourself, then theres nothing Nokia stores can do, becasuse you did it yourself. If a local service centre done it, take it back and moan to them, ask if they can do a software downgrade. |
05-05-2007, 09:52 | #18 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: India
Member: 222373 Status: Offline Thanks Meter: 9 | Quote:
thanks for your reply but I am not trying to tune, RX / TX, I dont know any thing about tunings what my L-3 center does but i got my phone repaired (dead to on) after tuning and they peply the reson "Tuning out of specs" for my dead handset. if you have any .pdf on tunnings pl send me on [email protected] and 'Catastophic Failiour' is not tobe a prob with my comp because I can flash another same model with out any prob so it should be a prob with phone, what it would be. & 1 more Q what do you mean by "MCU Did not boot" error given by phoenix while flashing. Thanks & Regards Vilas | |
05-07-2007, 21:31 | #27 (permalink) | |
Junior Member Join Date: Apr 2007
Member: 484738 Status: Offline Thanks Meter: 0 | simple flash does it ! Quote:
don't worry too much .all you need to do is a simple flash .i had the same problem with my nokia 6280 .i flashed it at repairman and now it is working better .it cost me about 10 dollars (120 moroccan dirhames) | |
05-08-2007, 12:29 | #28 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Zimbabwe
Member: 390858 Status: Offline Thanks Meter: 29 | 3510i randomly switching off please may you help because i have a 3510i which i have flashed before but the problem is that it randomly switches off.i also have the same problem with a 3310 please help. |
05-16-2007, 10:56 | #30 (permalink) |
Member: 132117 Status: Offline Thanks Meter: 3 | @chiefonline - your 3510i, is the imei still valid, press *#06# can you still see the imei? @goldace2003 - what have you done to the phone ? Have you tried changing the mic, or d-cover ? |
for morocan users post your box problem here | div_859 | FuriousGold | 2 | 06-04-2009 07:52 |
Post your software problems here | .::Unlocker.:: | Sony Ericsson | 67 | 04-03-2006 16:21 |
