Old 05-04-2007, 12:23   #1 (permalink)
MSG
Member: 132117
Thanks Meter: 3
Post Your Nokia Problems Below
Who am i ?
Im a Nokia certified engineer, been in the business for a long time.
Alot of people know my name from other forums...
What i am doing ?
You can post your nokia problems below, any random fault, rx / tx, power, camera etc etc
What program do i use ?
I always use phoenix, i have a full up to date registered version + dongle + imei rebuild. Feel free to ask me questions on Phoenix.
What do i use to tune phones?
I use phonestest. Feel free to ask me questions on phonetest..
What models am i a expert in ?
The whole range of dct 4 / 4.5 and BB5.
What is my aim?
To help you people with your problems you encounter. I'm on here daily, and will reply to all questions
What shall i do now ?
Ask me a question !!!
The Following User Says Thank You to MSG For This Useful Post:
Old 05-04-2007, 12:44   #2 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
hi sir i have nokia 3125 cdma .switch off after 32 sec. i changed conferm uem two time but problem is same.then i change flash ic but its same.what is the slution. thanks in advance.
Old 05-04-2007, 12:55   #3 (permalink)
MSG
Member: 132117
Thanks Meter: 3
after uem change did you write the PM file to the phone.
If you didn't the imei will still be ???????? and it will poer off after 32 sec.
You need to write imei reply file to the phones after uem.
Old 05-04-2007, 12:57   #4 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
Question 3125 off in 32 sec
[quote=nazar2008;2418227]hi sir i have nokia 3125 cdma .switch off after 32 sec. i changed conferm uem two time but problem is same.then i change flash ic but its same.what is the slution. i flash this set many time i just do everything but fail.please help me . thanks in advance .
Old 05-04-2007, 12:59   #5 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
sir its cdma nok 3125 ?should have to write pm after flashing .
Old 05-04-2007, 13:12   #6 (permalink)
MSG
Member: 132117
Thanks Meter: 3
@ nazur not after a software flash no.
If you change Flash IC or UEM then yes you have to rebuild IMEI.
Old 05-04-2007, 14:02   #7 (permalink)
Member: 222373
Thanks Meter: 9
Talking
Hi,
MSG
I am a L-2 service Enng.
pl. exp. what is the meaning of "Tuning out of specs" , by dooing tuning dead phones which dosenot respond to soft also comes up.
pl. post Details.
Thanks & Regards
Vilas
Old 05-04-2007, 14:28   #8 (permalink)
Member: 222373
Thanks Meter: 9
Hi,
pl. also tell me whatdo you mean by "Catastophic Failiour" which Phoenix pops up while sw update even pcd is untouched"
Thanks & Regards
Vilas
Old 05-04-2007, 14:48   #9 (permalink)
Member: 403881
Thanks Meter: 80
Dear MSG i need LCD ways for 6070 it will be kind enough if u could give me that as an earliest.
REGARDS,
Old 05-04-2007, 22:49   #10 (permalink)
MSG
Member: 132117
Thanks Meter: 3
@ Vilas - What are you trying to tune, RX / TX? What phone? Also what program?
I'm guessing you're trying to tune TX, and when you click 'next' it comes up with that error. Try tuning the bottom coffecient level 'base'
@ Vilas 'Catastophic Failiour' could mean there is a problem with your computer hardware. Maybe there is a comflict somewhere. Are you trying upgrade phone software or downgrade phone software.
@Sarojrkl - As a Nokia engineer, nokia don't let us do short-cuts or 'jumps' on pcb's (example your 6070 lcd ways)
In my view, I'd BER the phone.
It would be best to search the forum, using the search button in top corner.
Old 05-05-2007, 05:09   #11 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
32 sec off 3125
hi everydody i have nokia cdma 3125 with 32 sec getting off problem.please help me
Old 05-05-2007, 05:19   #12 (permalink)
Member: 403881
Thanks Meter: 80
Dear MSG,
First of all thank you so much for replying .Another problem i have that is, one 2600 set is functioning well but in OFF condition when i put charger only light come it does not charge. In ON condition when put charger it does not show any thing. Waiting for your valuable solution.
Regards,
Old 05-05-2007, 05:51   #13 (permalink)
Member: 445609
Thanks Meter: 27
sir are you fond of digrams?my 7650 wont charge and the # button wont function...ive already change flex cables but still wont work..tnx in advance
Old 05-05-2007, 05:52   #14 (permalink)
Member: 445609
Thanks Meter: 27
dear msg,i need keypad diagram for n7650
Old 05-05-2007, 06:10   #15 (permalink)
Member: 396911
nokia released 3.066 firmware, which i updated to, only they didn't mention "oh, it will make your blackberry software non-functional, and we don't have an update to the blackberry software." and the nokia store told me "sorry, can't do anyhting but buy a new phone."
any chance its possible to get it back to the old firmware?
for morocan users post your box problem here div_859 FuriousGold 2 06-04-2009 07:52
Post your software problems here .::Unlocker.:: Sony Ericsson 67 04-03-2006 16:21
Page generated in 0.23114 seconds with 10 queries
