Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 08-28-2002, 18:26   #1 (permalink)
Member: 11632
Problem with 3310. Freeze & restart
I have a problem with 3310. Sometimes it work OK, but when I press 1, 4 or Menu it restart or freeze. Please help.
Thanks in advance.
Old 08-28-2002, 18:41   #2 (permalink)
Member: 4873
try cleaning board contacts or replace power switch mate
Old 08-28-2002, 23:12   #3 (permalink)
Member: 14068
Tray to change software.
Old 08-28-2002, 23:42   #4 (permalink)
Member: 11632
I change soft, but no luck. No SW is 5.57. Was 4.45
Old 08-29-2002, 07:15   #5 (permalink)
Member: 1060
Re: Problem with 3310. Freeze & restart
Barvik,,
How about you will try without SIM CARD and press 1 4 7 * ???
check also at TXCO cold solder !
Willy
Thanks in advance.
Old 08-29-2002, 12:46   #6 (permalink)
tgsm's Avatar
Member: 13827
rehot flash and ram IC
Old 09-01-2002, 19:04   #7 (permalink)
Member: 14194
Hi barvik
try to solder the L511 then reset factory setting with nokia tool,
goodluck
Wesam
Old 09-01-2002, 23:20   #8 (permalink)
Member: 1060
Wesam,
I am sorry,, but when you said--> solder L511,, your mean, that L511 is dead ,, need to replace , or it was cold solder ?
Willy
Originally posted by wesam
Hi barvik
goodluck
Wesam
Old 09-02-2002, 00:56   #9 (permalink)
Member: 14194
Dear willy,barvik
sorry for my english
I mean to remove L511 then reset factory setting without it ,
plieve me it sucssisful with me on many phone,
goodluck
Wesam
Old 09-02-2002, 04:47   #10 (permalink)
Member: 11632
With removing L511 nothing changes.
Old 09-02-2002, 17:39   #11 (permalink)
Member: 12724
dear willy what is your idea in this case?
Don't you think barvik can remove and solve the problem with flashing the phone?
Old 09-02-2002, 18:11   #12 (permalink)
Member: 1060
Hello Light,
Thanks,
like membar barvik said :
" have a problem with 3310. Sometimes it work OK, but when I press 1, 4 or Menu it restart or freeze"
sound look like phone were hung, that is reason why, i ask barvik,, if this phone does not put any sim card,, what happen is it ?
When it become "some time"....
1: Flash ROM or RAM and MCU had cold solder or rusty on pad.
2: CCONT 32.768K sleep clock not good working
3: 26/13 Mhz path open circuit, or level too low
4: battery connector no good : BSI in to CCONT, identify wrong battery type for wrong phone running mode
5: MCU to Hager control , lost timing via SCLK and SDATA , and can not read hager temperature and reset it !
6 7 8 ,,,,,,, there is too many reason will be .
but here i am talking,, "as if " phone SW have no problem !
Regard
Willy
Old 04-03-2004, 15:29   #13 (permalink)
Genius's Avatar
Member: 12663
I have also same problem with 3310, it freeze and restart's.
There is no diference if I put SIM inside or without it.
Same problem remain's.
Phone work without restarting registered to network ok, but when I tray to insert menu
or make a call, phone freeze and restart.
Any idea???
B.R
GeniuSShadoW
Old 04-03-2004, 18:00   #14 (permalink)
Member: 45635
dont waste your time ! change cobba ...........
Old 04-03-2004, 19:13   #15 (permalink)
GSMWolf's Avatar
Member: 4454
cobba? R U crazy?
all what says Willy is right, first of all rehot flash and ram ( or reball - clear oxidation under it) .
than check ( change) all clocks in phone, than change ccont and hagar. ....hagar only divide 26Mhz to 13Mhz, i think this dont help, but try it....
it is strange that phone freezes only when press menu or 1,4....If phone freezes with pressing 7 too, it isn so hard to repair....but only menu, 1,4 ....strange...strange...
Wolf.
Problem with samsung freezing nasir_jhb UFS2 + UFS3-Tornadoflasher 1 11-25-2005 20:49
2650 Freeze & Restart itself cellularry Nokia Digital Core Technology 4 ( DCT-4 ) 1 10-09-2005 04:46
Problem with server freezing One Eyed Snake TOTAL MultiServer 6 02-03-2005 06:17
Problem with 3310 & Logomanager simonb Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 10-17-2001 08:31
Page generated in 0.38917 seconds with 11 queries
