PHP Code:
Connection opened successfully
IF Boot Init : 0xF0
IF Resp Len : 0x0A
IF xCPUID : XGOLD 213 [XMM2130 QUANTUM]
IF Resp Data : 1FB300020303010100FF
Sending EBL Loader ...
EBL Loader Ok, 01
EBL Loader ready, AA
Sending EBL ...
EBL sent Ok
EBL : Quantum_Bootloader_10.47_M1S1
Speed accepted, use 6.500.000
FLASHID : EC001230
FLIC conf set, RST set
Boot done!
Check keys...
Check done. Image can be flashed
Backup enabled, will read all certificates
Reading CCC
Reading HWC
Reading NPC
IMEI 1 : 355948053647344
IMEI 2 : 355948053647351
PCcode : '
îrƒ¹á
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : C:\InfinityBox\BEST\Backup\Cert\355948053647344_2nd_XG213_CRT.rpl
===Flashing [MCU]===
File : rm834__20.52.mcusw
Image : rm834__20.52.mcusw_ebl_psi.fls
Sec-pack found, sending ...
Sec-pack sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:02
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01B40000
Erasing, wait ...
Erase done, time : 00:00:55
Write , Start : 0x40280000 , Len : 0x01AC0000
Flashing , wait ...
Region flash done, time : 00:00:47
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
===Flashing [PPM]===
File : rm834__20.52.ppm_c
Image : package_c.ppm_ebl_psi.fls
Sec-pack sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41DC0000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:00:09
Write , Start : 0x41DC0000 , Len : 0x00475FE0
Flashing , wait ...
Region flash done, time : 00:00:05
===Flashing [CNT]===
File : rm834__20.52.image_c_059N1N8_059Q027_351_01
Image : rm834__20.52.image_c_059N1N8_059Q027_351_01.fls
Sec-pack sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x424C0000 , Len : 0x01960000
Erasing, wait ...
Erase done, time : 00:00:57
Write , Start : 0x424C0000 , Len : 0x00C40000
Flashing , wait ...
Region flash done, time : 00:00:17
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:03:20
Reboot phone now...
Reading Phone Info....
Connected phone - 202
Software Info: V 20.52 27-09-12 RM-834 (c) Nokia
IMEI: 355948053647344
PPM version : V 20.52 27-09-12 RM-834 (c) Nokia C
Product code: 059N1L0
Wait, when phone will be ready ...
Checking...
SimLock status : SimLock is Ok
Security status : Security is Ok
Read Info Done!
Processing After Flash Defaults...
FullFactorySet... Ok!
UserDataDefaultsSet...OK!
ServiceDefaultsSet... Ok!
LeaveDefaultsSet... Ok!
ProductTuneSet...OK!
SwUpgradeSet...OK!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
Battery voltage is enough for start
AfterFlash operations done ;D
Done!
Connect phone on selected interface...
Elapsed: 00:04:20
Phone found!
Series 40 Device detected!
read info... - Ok
