06-23-2005, 13:20 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | Problem flashing dead 3650, please help... Fl0: 0x00000000-0x007FFFFF,0001257E,Amd 29BDS643GT Fl1: 0x02000000-0x027FFFFF,0001257E,Amd 29BDS643GT Fl2: 0x04000000-0x047FFFFF,25020040, Algorithm: w2_amd.fia, w2_cbusb.fia Algorithm Ok, MSID: 841623326B4F39703AC773641D Decoded MSID: 3E4EBAF7-000A8EA8-A8000000 Encoded FAID: 6294B8D6-1174BBE1-8ACC7F57 Cbus Boot Error: 9 Error Data1: 00000000: 00 96 84 16 23 32 6B 4F 39 70 3A C7 73 64 1D B8 ....#2kO9p:.sd.. 00000010: 25 02 25 40 00 04 01 00 7E 25 02 25 40 00 06 00 %.%@....~%.%@... 00000020: 00 01 00 00 00 00 00 FF FF FF FF FF FF FF FF FF ................ 00000030: FF FF FF FF FF FF FF DD 00 00 00 00 00 00 00 00 ................ Error Data2: 00000000: A3 72 72 7E 25 02 25 40 00 02 01 00 7E 25 02 25 .rr~%.%@....~%.% 00000010: 40 00 04 01 00 7E 25 02 25 40 00 06 00 00 01 00 @....~%.%@...... 00000020: 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF ................ 00000030: FF FF FF FF DD C3 72 00 00 00 00 00 00 00 00 00 ......r......... Before taking screenshot, expand this window ! Process Failed, Repowering Mobile today I flash a dead 3650 and I got this, I think this is flash IC fault " Fl2: 0x04000000-0x047FFFFF,25020040," but i don't know where the IC?, or maybe there are any solution to fix this one? please help.... Last edited by pazeth™; 06-23-2005 at 15:39. Reason: please make my 3650 life again... |
06-23-2005, 18:15 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 47
Member: 135671 Status: Offline Thanks Meter: 45 | I have the same prolem to Nokia 3650 I 'm trying to flash and erase Flash reflash again , after i Set UI setting, Format area , But screen is balnk. What is prolem . Help me about it. |
08-21-2005, 12:45 | #5 (permalink) |
Freak Poster Join Date: Apr 2005 Location: portugal Age: 46
Member: 134158 Status: Offline Thanks Meter: 30 | Its very simple just use other vertion of dctx and disable autodetect and inisettings and use xslow flashing if wil not result replace fiafiles fo 3.19 --- goodluck |
08-21-2005, 15:15 | #6 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Everywere Age: 46
Member: 18057 Status: Offline Thanks Meter: 64 | @ all my dears pls. .... check where is 3rd flash not dispalyed his name. refresh it or change it . Fl0: 0x00000000-0x007FFFFF,0001257E,Amd 29BDS643GT Fl1: 0x02000000-0x027FFFFF,0001257E,Amd 29BDS643GT Fl2: 0x04000000-0x047FFFFF,25020040,----------------??????????????? @kki |
09-24-2005, 21:05 | #7 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: Coimbra - Portugal Age: 46
Member: 77227 Status: Offline Thanks Meter: 26 | Quote:
09-25-2005, 03:28 | #8 (permalink) |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | i think you have water damged from the bottom board because the last flash down not recognaized by flasher also the blue tooth damaged i recommend the following 1-clean the board 2-try to re ball flash ic no. fl2 3-try remove the blutooth module 4-flash the phone without flashing bt 5-when phone revived (i hope) use new or working bluetooth or even fix the old one br., raheeeeeb |
09-26-2005, 05:25 | #9 (permalink) | |
Member: 135671 Status: Offline Thanks Meter: 45 | Quote:
I 'm have to do it but can not turn it normal. After i turn it on then phone turn off. I have it wrong RAM IC. Best & regards | |
08-30-2006, 11:00 | #10 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Islamabad, Pakistan Age: 42
Member: 48857 Status: Offline Thanks Meter: 31 | 1st Boot Ok, WD2, UPP: 0082 Fl0: 0x00000000-0x007FFFFF,0001257E,Amd 29BDS643GT Fl1: 0x02000000-0x027FFFFF,0001257E,Amd 29BDS643GT Fl2: 0x04000000-0x047FFFFF,0001257E,Amd 29BDS643GT Algorithm: w2_amd.fia, w2_cbusb.fia, Ver: 4.52.0 Algorithm Ok, MSID: 84860FBE57C601397122067384 Decoded MSID: 3E4EBAE9-00467B13-A8000000 Encoded FAID: 451C9CD5-B5736D38-E6D7024C Cbus Boot Error: 9 Error Data1: 00000000: 00 96 84 86 0F BE 57 C6 01 39 71 22 06 73 84 41 ......W..9q".s.A 00000010: 00 7E 25 02 00 40 00 10 00 04 01 00 7E 25 02 00 .~%..@......~%.. 00000020: 40 00 10 00 06 00 00 01 00 00 00 00 00 00 00 C9 @............... 00000030: 00 00 EA 07 01 00 EA 06 01 00 EA 05 01 00 EA 82 ................ Error Data2: 00000000: A3 72 72 7E 25 02 00 40 00 10 00 02 01 00 7E 25 .rr~%..@......~% 00000010: 02 00 40 00 10 00 04 01 00 7E 25 02 00 40 00 10 ..@......~%..@.. 00000020: 00 06 00 00 01 00 00 00 00 00 00 00 C9 00 00 EA ................ 00000030: 07 01 00 EA 06 01 00 EA 05 01 00 EA 82 C3 72 00 ..............r. Before taking screenshot, expand this window ! Process Failed, Repowering Mobile well this is the case with my 3650, it works fine when i dont flash blutooth during flashing. but bluetooth dont work. may be i will have to change bluetooth module |
g600 problem flashing error boot please help!? | gprsman | HWK | 11 | 03-26-2010 20:31 |
Problem Flashing Lg U830 Please Help!!! | DESBLOKING | FuriousGold | 4 | 04-23-2007 15:57 |
Problem flashing vith Victor. Please help ! | Tanatos | Motorola P2k | 0 | 09-16-2004 19:18 |
