06-05-2008, 10:53 | #1 (permalink) |
Freak Poster Join Date: Jan 2008 Location: Kerala, India
Member: 676100 Status: Offline Sonork: 100.1577777 Thanks Meter: 18 | ""problem In Flashing Nokia 2626 Please Help Me"" JAF version 1.98.50 Detected PKEY: 9001141F Card life counter: 93.36% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30112 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE INI file .ini is missing. Continue searching for second ini type... Changing flashing settings... FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_03.080 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_03.08md CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh700_nai3.08aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Filipino,Vietnamase MCU: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_03.080 Booting phone... Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC This MCU ID is not supported in chosen flash file... Error booting phone... Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC Failed!!! MCU: C:\Program Files\Nokia\Phoenix\Products\RH-70\rh70_03.080 Booting phone... Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC Cannot find boot file... Error booting phone... Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC Failed!!! Powering the phone... Failed! Aborting! Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... Phone didn't answer with TX line high after UEM reset! Causes: 1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line. 2.UEM damaged -> replace UEM. MCU ID: 0xCCCC Failed!!! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Backup IMEI zone... Setting local mode... Reading IMEI... Reading IMEI data... Building RPL backup file... C:\Program Files\ODEON\JAF\ProgData\352770012195840_imei_back up_151556.rpl Done! Getting MCUID... MCU ID: 0x3040 Reading flash chip detailes... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x3040 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_ic CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.image_ic ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Arabic,French,Swahili CNT: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.image_ic Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: c5 Loader is ready... P-key nokia module version 01.02 MSID: 8434B0A9928751125BCAADB823 MSID decoded: D26EBAF10006794EAA000610 FAID: A068743B5C4B11BB18891E8A Operation took 0 minutes 12 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01B80000 - 01EDFFFF... Operation took 0 minutes 23 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 11 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Extracting Content Pack... Error setting local mode... CP Extract Failed! PPM: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_ic Booting phone... MCU ID: 0x3040 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0xE822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 25 Loader is ready... P-key nokia module version 01.02 MSID: 843BB4680BD1D94CBE00DA1ADB MSID decoded: 3E4EBAE90006794EA9000000 FAID: 118E9F9EAA2068EF41ABAA15 Operation took 0 minutes 11 seconds... Erasing PPM... Found 1 interval(s) to erase Erasing area: 018E0000 - 01B7FFFF... Operation took 0 minutes 19 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 10 seconds... Restarting MCU... Flashing Done! Operation took 1 minutes 55 seconds... After flash processing... Waiting for phone to boot... Failed! Aborting! PLEASE HELP ME |
09-27-2008, 11:57 | #3 (permalink) | |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
u must full erase flash memory then flash muc+ppm+cnt post result | |
""I want to unlock Nokia 6061 - please help me"" | rajeevpchandran | HWK | 0 | 08-12-2008 13:57 |
""problem In Flashing Nokia 3230 Please Help Me"" | rajeevpchandran | Nokia Hardware & Hardware Repair | 3 | 06-06-2008 09:06 |
""problem In Flashing Nokia 3230 Please Help Me"" | rajeevpchandran | J.A.F. By Jafsupport.com | 0 | 06-03-2008 17:19 |
