Old 01-04-2011, 11:28   #1 (permalink)
MGT SOFTWARE's Avatar
Member: 53263
Sonork: gsm master
Thanks Meter: 326
Re: N97 charging prob, Low Battery
I quoted fron Nokia care but i have same prom look here:-
Hi, I've had my N97 for about 2 weeks and charge it at home (with charger supplied) in the car (with adaptor supplied) and at work through USB cable also supplied. A few times i have noticed that it was running low on charge and whist this was annoying compared to my last Nokia (E90) i figured that it nust be down to all the radios the N97 has (i have BT & WiFi on all the time).
However i have noticed just in the past couple of days that it does not appear to charge in the car. Since getting the N97 the charging adaptor supplied has got very hot and i have tried several other leads and a freinds N97 adaptor but they all seem to get hot. This would explain why i am not recharging during the day (i have 1hr each way commute)
I also experienced the battery indicator indicating that it was charging even when i had removed the charger and the small white light next to charger/USB port was still on....a quick battery removal reboot cured but i have had it twice since.
Today however i have had to spend an hour just getting the N97 to a) boot up and allow me to access controls b) take any charge at all!
I have lost track of the switch off...battery out...reboot combinations so i can't even tell you how i got it working again...but my question is who else is having the same problems...and any sign of a cure?
Old 02-06-2011, 14:39   #2 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
HI, i have the same problem, my N97 descarge alls the batteries also whith charger connected, have testated in alls mode, 5 New batteries, charger different, USB, Normal charger in dotation, but this phone, forever descarge alls the batteries also in standby in small time, do u have solved this?, becouse read here:
"need professional here with n97"
http://forum.gsmhosting.com/vbb/f550...6/#post6923683
Max
The Following 2 Users Say Thank You to .:Ripgsm:. For This Useful Post:
Old 02-06-2011, 14:43   #3 (permalink)
$h@hidmobile$'s Avatar
Member: 652132
Thanks Meter: 146
Max
brother change battry IC............
Old 02-09-2011, 11:43   #4 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Bro, i have searched in alls part this IC, but not have find this IC, can you help me where i can find this IC?, and another question, i have only Hot Air Station is possible desolder and after solder the new IC whith only Hot air Station?, i think is one small trouble this, but who have done this work, know if is possible this, thank for the answer,
br
Max
Old 02-09-2011, 12:41   #5 (permalink)
Member: 1508980
Thanks Meter: 4
Thanks for suggition
Old 03-10-2011, 06:16   #6 (permalink)
Member: 664954
Thanks Meter: 12
hi can anyone give me solution for nokia n97 can't detect simcard after i chage usb connector, i realy need argent. thankssss.
Old 03-12-2011, 11:06   #7 (permalink)
.:Ripgsm:.'s Avatar
Member: 125945
Thanks Meter: 495
Bro, but becouse for shure do u have sended in the PCB very many High calor and have demaged one IC of reader Sim, tha USB connector, if do u have usated Hot Air, not is good, but was need Infrared for this operation, how more parts in N97,
wbr
max
Charging. PhoeniX Nokia Hardware & Hardware Repair 7 07-06-2004 08:35
Ultra Slim Vibra Battery? ZF Nokia Hardware & Hardware Repair 2 11-10-2000 15:12
GSM Cables, Dual SIM Covers/Batteries jat Main Sales Section 1 10-04-2000 17:52
looking schematic for nokia5161 battery with vibra dofie Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-13-2000 22:48
Li-ion batteries for your cellular phones hankong Main Sales Section 0 10-02-1999 05:38
Page generated in 0.16683 seconds with 9 queries
