04-19-2004, 03:05 | #1 (permalink) |
Freak Poster Join Date: May 2002 Location: Portugal Age: 42
Member: 12207 Status: Offline Thanks Meter: 2 | Re-using UEM?? I have one nok 7650 wich has a uem with a good imei! now, i want to change this uem to a nokia 8310! can i change it, and will the 8310 work? Oh, 7650 is pretty dead, so it's helpless to read flash imei data from it! Thanks in advance Regards XARiUS |
04-19-2004, 03:27 | #2 (permalink) | |
Junior Member Join Date: Jul 2002 Location: Quezon city, philippines
Member: 13987 Status: Offline Sonork: None Thanks Meter: 2 | Quote:
It won't work UEM is one time programming only, better use a brand new UEM | |
04-19-2004, 14:33 | #5 (permalink) |
Freak Poster Join Date: Jan 2003 Location: SL 550 Age: 48
Member: 20490 Status: Offline Thanks Meter: 3 | using from another dead 8310 to the damaged imei 8310 is not possible?! i think 7650 uem is different from 8310 uem anyway i'll post soon my results. BR |
04-19-2004, 18:30 | #6 (permalink) |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | All the UEMs are the same ,they worksfor each phones. dont use an exess heat , install the ( known IMEI ) UEM in the new phone , make an ASK file , requset an RPL on that ASK file , and finaly upload it. As U see it is the usuall routein , but now it works |
04-19-2004, 20:27 | #7 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | for the 8310 .. if you use "total" new UEM, then any OLD ( type 2 ) RPL will work ! for you like to remove UEM 7650 and install to 8310, it will work-----> if you can make rpl by your own ! ( but not good ) becasue your 8310 will have same IMEI to 7650 , it mean, you have to have know 7650 original IMEI Regard |
04-20-2004, 00:12 | #9 (permalink) | |
No Life Poster Join Date: Oct 2001 Location: -------- Age: 55
Member: 7062 Status: Offline Thanks Meter: 126 | Quote:
did the data 1 same in type 2 and type 5 wd2 series?? did this not affect the msid to inhance the network data correctly ??? | |
04-20-2004, 05:03 | #11 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | You just need Griffin team account for Flash IMEI rebuild (or friend with account for you, or similar service from someone...) . Place good working (and not empty!) UEM (from your 7650 for example) in your N8310. Readout ask file (this file will containt already programed in UEM IMEI - in your case - from 7650) - Griffin server will recalculate for you Flash UEM rebuild *.rpl file - upload this file to phone - enjoy! |
04-20-2004, 05:58 | #12 (permalink) |
Member: 12207 Status: Offline Thanks Meter: 2 | Hi! First, thanks to all for your help! It really helped me a lot! Oh, to the guys who missunderstood my question... The 7650 is completely dead! So it won't be 2 phones with the same IMEI because 7650 will not functioning again! That's why i wanna get the UEM and re-use it! Too bad i can't read 7650 IMEI data from flash, because a took it off, and i'm not able to reballing it! Again... Thanks to alll... Regards XARiUS |
01-07-2005, 13:53 | #14 (permalink) |
Junior Member Join Date: Mar 2004 Age: 43
Member: 58665 Status: Offline Thanks Meter: 0 | you can not do this uem is just for one phone and when it write once you cant rewrite it so you cant use uem of one phone for another however they are same phone its not possible my friend and i think its better to buy a new uem and write it with griffin or ufs good luck |
06-14-2005, 08:23 | #15 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Beograd Age: 48
Member: 80255 Status: Offline Thanks Meter: 15 | It is posibile but you must wrote same rpl to uem like wroten first time, i tested, change same uem in 3100, 6610, 3200, every time wrote same rpl and phone working good, that can use to test anodher function of phone if everything ok put him new uem. BEST REGARDS |
re-using sim cards | fofodaman | Sim Cloning and Scaning | 17 | 10-06-2013 10:07 |
after SD calculation, then there is a backup file,can re used it again ? | mantok | Universalbox | 20 | 12-22-2009 11:49 |
re use old box - how to get support | fordgt40 | HWK | 6 | 03-27-2008 09:20 |
trouble flashing used-uem n flash | ufs_ternoda | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 12-02-2007 03:11 |
