06-07-2006, 10:06 | #1 (permalink) |
Freak Poster Join Date: Dec 2005
Member: 210449 Status: Offline Thanks Meter: 2 | regarding nokia 2100,flashed bt still hope all r fine. well im having problm on nokia 21oo. it showed contact service. whn i flased wt ufs 3 flasher,and again i setted the UI Setting too. bt still showing "contact service" hw can i fix this problem?? pls thanks in advance wt lov |
08-14-2006, 18:23 | #5 (permalink) |
No Life Poster Join Date: May 2006 Location: Tanzania
Member: 271974 Status: Offline Thanks Meter: 97 | Hi some times contact service can be caused by hard ware fault.So if you have try to reflash but still problem un solved try to reball or change cobba ic. |
08-15-2006, 00:02 | #6 (permalink) |
Junior Member Join Date: Aug 2006
Member: 322577 Status: Offline Thanks Meter: 6 | PLS I WANT TO KNOW YOUR LOCATION AS WELL AS YOU E;MAIL ADD.BCOS OF FUTHER THING TO LET ME KNOW ABOUT.I HAVE CHANGE THE COBBA WITH LUCKY SMD MODEL NO. 852D & THE PHONE DIES THEREFORE I W ANT TO KNOW GOOD EQUIPMENT USE TO CHANGE THE IC, LIKE 3310 CCONT, 2100 COBBA AND OTHER BGA ICS. |
08-15-2006, 09:44 | #7 (permalink) |
Junior Member Join Date: Mar 2006
Member: 251413 Status: Offline Thanks Meter: 0 | HI, I have a 3610 contact service when flash with ufs it's shows.. 1st Boot Ok 2nd Boot Ok, DCT3, MAD: A1 G-01, ROM: 6, BUS: 16 FLID: 008988C2,Int 28F1602C3-T, I28f160.tia Software: Algorithm Ok, [185A] Erasing: 0x00200000-0x0048FFFF Erasing Error: 10,at: 0x00400000-0040FFFF, 910206 Process Failed, Repowering Mobile Any solution?? Please help me...thanks. |
09-30-2006, 09:40 | #10 (permalink) | |
Freak Poster Join Date: May 2006 Location: Delhi
Member: 284196 Status: Offline Sonork: 100.1640403 Thanks Meter: 250 | Quote:
abhishek Last edited by abhishek aga; 09-30-2006 at 09:51. | |
09-30-2006, 09:50 | #11 (permalink) | |
abhishek | |
nokia 2100 contact service --still problem after flash--- | crossings | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 49 | 11-11-2007 17:06 |
nokia 2100 flashed ok but can not power on | barthosyn | Nokia Hardware & Hardware Repair | 6 | 12-16-2005 02:04 |
Nokia 2100 flashing ???????? | xacker | Nokia Multimedia | 1 | 09-29-2003 22:38 |
