12-16-2008, 20:17 | #1 (permalink) |
Junior Member Join Date: Dec 2008
Member: 925758 Status: Offline Thanks Meter: 0 | Removing 6220 classic keypad I'd like to remove my 6220 classic keypad in order to insert some paper underneath (to improve the keypad feel). Can anyone tell me how to unclip the keypad please? I don't want to snap anything by prising the wrong spot! Thanks, Ian |
12-16-2008, 20:58 | #2 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: Czech republic Age: 54
Member: 56634 Status: Offline Thanks Meter: 71 | Quote:
I hope as though find what need nokia photos repair pack http://rapidshare.com/files/17386240...r_fot-pack.rar point of view http://rapidshare.com/files/173862869/nokia.avi password:nokia | |
12-17-2008, 00:09 | #4 (permalink) |
Member: 925918 Status: Offline Thanks Meter: 0 | are you able to remove the front? if so, using a screwdriver while pulling "outwards" on the snaps will release them. Usually, releasing the top ones will allow you "wiggle" it off, if not, release the bottom one but be more careful here. |
12-18-2008, 16:24 | #6 (permalink) | |
Member: 925758 Status: Offline Thanks Meter: 0 | Quote:
Unfortunately the comprehensive rar file linked to above doesn't contain any images of the 6220 classic, only the original 6220. Ian | |
12-22-2008, 21:46 | #7 (permalink) |
Member: 925918 Status: Offline Thanks Meter: 0 | You can remove the front without any screws. The best way is to use a nokia plector, and slide it under the cover, right where the front makes a sort of contour. Do it on both sides and you should be able to remove it. And dont forget to remove the battery cover first. |
Nokia 6220 Classic Keypad Keyboard With Flex Cable required | badal007 | GSM Mobile Links | 1 | 06-02-2010 12:42 |
Red led Remove while recording video in 6220 classic | roadboy6 | Nokia Multimedia | 0 | 10-23-2009 19:43 |
6220 classic how to install unsigned applications | gsmindia | Nokia Multimedia | 3 | 12-12-2008 18:13 |
nokia 6220 classic mmc problem 100%100000000000000 ok | ProfessoR-TEAM | Nokia Hardware & Hardware Repair | 3 | 06-28-2008 14:55 |
