04-23-2002, 06:40 | #1 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Croatia Age: 45
Member: 4185 Status: Offline Thanks Meter: 3 | Repairing blank display on 8210......... Is there any solution to repair this without changing display??? because the display as i know isnt faulty.because when i try it with 10 pieces of 8210 it works on 2 pieces without problem....... So it must be something in hardware difference....... Thanx...regards........... |
04-23-2002, 08:10 | #2 (permalink) |
Insane Poster Join Date: Sep 2001 Location: Kent, UK
Member: 6267 Status: Offline Thanks Meter: 0 | you might find it works OK on some phone and not on others, I had an LCD that was doing the same thing. intermittant on just a few phones. I check on the Clubnokia Engineering Bulletins and found that there is a massive batch of 8210 LCD's that are faulty, if you look at the bottom of the LCD/keypad frame just below the 0 key you will see a batch number in black, if the batch number begins E7 then the LCD is 100% faulty and also many of the ones that start E6 are also faulty. A nokia service point will swap this without question, |
04-24-2002, 15:37 | #3 (permalink) |
Freak Poster Join Date: Dec 2001
Member: 8214 Status: Offline Thanks Meter: 0 | u can solve this problem, without changing the lcd. one of our mate give me this solution, just resolder the condensors in the lcd, if it is not working change the condensors in the lcd. keep cool & Cheers regards |
04-24-2002, 19:38 | #4 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Ukraine Age: 46
Member: 7767 Status: Offline Thanks Meter: 3 | This solution with changeing capacitors is not usefull. It works on 30%. Dissapearing appears later (after 3-5 min into inbox). Changeing displays - 100% true solution. |
04-25-2002, 02:23 | #5 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Russia Moscow Age: 46
Member: 5889 Status: Offline Thanks Meter: 0 | The best way for repairing 3310 : get display from 3210 and insert in 3310 ?bad? display from 3310 insert in 3210 BOTH PHONES WORK FINE for 8210 only new display tested with several phones |
04-25-2002, 19:08 | #9 (permalink) |
Freak Poster Join Date: Feb 2001 Location: Czech Republic Age: 46
Member: 3357 Status: Offline Thanks Meter: 2 | - for 8210 change C331 (on phone PCB) from 100nF to 470nf or higher....(you may also change capacitor on disp to higher cap.)....yes it's true that cap. change will help only for some displays...cca 60% of that phones will have that fault in some days again......(E7,E6 8210 LCDs has very poor quality and changing characteristic for some time) - for 3310 change C410 from 470nF to 1uF...it works for me (no phones returned back) regards Vicky Last edited by Vicky; 04-25-2002 at 20:52. |
nokia 1200 blank display & 1208 blue display solution | mobilecitycbk | Nokia Hardware & Hardware Repair | 4 | 11-27-2017 23:01 |
N95 8GB blank Display key pad light on | mohit_kripalu01 | Nokia Hardware & Hardware Repair | 61 | 07-26-2013 11:48 |
w580i after repair gdfs show blank display | /\/\A/\/| | D-Unlock Suite | 0 | 12-21-2009 15:14 |
Strange display on 8210 (numbers running around) | smartfone | Nokia Hardware & Hardware Repair | 7 | 08-14-2005 14:07 |
display on 8210 | vampire | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-22-2000 09:42 |
