08-08-2002, 07:46 | #1 (permalink) |
No Life Poster Join Date: Jan 2002 Location: MARS
Member: 8304 Status: Offline Thanks Meter: 362 | Replace Your Pa Here!!!!! 1 - SET YOUR HOT AIR TEMP TO +-450C, AIR FLOW LEVEL TO HIGH 2 - HEAT UNDERSIDE OF PA UNTIL SOLDER BUBBLES 3 - NOW SET AIRFLOW LEVEL TO MEDIUM AND HEAT TOPSIDE 4 - THEN SLOWLY LIFT PA WITH SHARP FLAT METAL OBJECT 5 - DO NOT APPLY TOO MUCH FORCE WHEN LIFTING PA,YOU WILL DAMAGE SOLDER PADS ON PCB,NOT REPLACEABLE. 6 - CLEAN SOLDER PADS WITH A GOOD CLEANER E.G (ALCOHOL) 7 - ALIGN NEW PA ON PCB CORRECTLY AND DO STEP 3. 8 - WHILE APPLYING SLIGHT PRESSURE WITH FLAT METAL OBJECT ON TOP HEAT THE PA UNDERNEATH UNTIL PA IS PRESSED FLAT ON PCB. 9 - ALLOW PA TO COOL OFF FOR ABOUT 1MIN AND TEST PHONE. HINTS: 1 - FAULTY PA IS NORMALLY CAUSED BY TRANSCEIVER BEING DROPPED TOO HARD,MOISTURE,OR FAULTY FACTORY PART 2 - NEVER SUBSTITUE BRAND NAMES WHEN REPLACING PA E.G, (REPLACING HITACHI PA WITH PHILIPS PA).THIS WILL CAUSE MIS-ALIGNMENT AND PA WONT WORK 3 - WHEN PA IS PHYSICALLY DAMAGED IT NORMALLY CRACKS UNDERNEATH. 4 - IN CASE OF 82XX REMOVE POWER SWITCH BEFORE REMOVING PA BECAUSE TOO HIGH TEMP WILL MELT PLASTIC IN SWITCH. 5 - ALWAYS PRACTICE WITH DEAD PCB BEFORE TRYING THIS SKILL ON WORKING PHONE. PS:ANYBODY WITH MORE INFO PLEASE POST HERE!!! PA List Nokia 3110 PF01412A Nokia 3210 (Gsm 900Mhz-PF01420B)(Gsm 1800Mhz-PF04110B) Nokia 33XX PF08109BN/RF3103/BGY270/PF08112B Nokia 5130 4370275 Nokia 5110 PHILIPSBGY251 Nokia 6110 4370319 Nokia 6150 Nokia 6210 PF08103B Nokia 7110 PF01411B Nokia 8810 PF01411B Nokia 8850 PF08103B Nokia 82XX PF08103B/PF08105A Maxon 3204 PF01411A Ericsson T10s AND630 Eriksson A1018s T014 Ericsson A1018s PF08105 Ericsson T28s RM009 Sagem MC922 GY2014 Sagem MC922 RF2173 Siemens S10 PF01414A Siemens C10 PF01414A Siemens C25 PF08103A Siemens S25 PF08103A Siemens C/M/S35 PF08109B/PF08112B Philips Savvy DB PF08103B Philips Savvy PHILIPSBGY241 Sagem RC715 M2006 Alcatel HD1 M2006 Philips Genie PF01412A |
08-10-2002, 18:03 | #8 (permalink) |
Insane Poster Join Date: Mar 2002 Location: Computer Hospital Age: 47
Member: 9828 Status: Offline Thanks Meter: 2 | mujie; my question is: 1. are you sure the actual/approx. temp is 450 deg. celsius on the hot air? i think this temp. is enough to burn the PCB or might cause warping of the board. did you use digital thermometer to read the actual temp.? if not how could you estimate if it's approx. 450 deg. celsius. 2. how much is the time heat exposure of the newly replaced PA to prevent damage from it? |
08-11-2002, 05:05 | #9 (permalink) |
Member: 8304 Status: Offline Thanks Meter: 362 | 450C OF ***** FLAME WILL SURELY DAMAGE PCB,THAT TEMP I SET ON MY MAGNUM HOT AIR STATION,IT IS 450C.IF YOU USE A LOWER TEMP E.G(300C-350C) PA REMOVAL WILL TAKE 6MIN AT LEAST. TIME TAKEN TO REMOVE PA IS ABOUT 30-40SEC WITHOUT DAMAGE.I'VE BEEN REPLACING PA WITH THIS METHOD FOR OVER 2 YRS,AND I NEVER DAMAGED 1 PA. |
08-11-2002, 12:41 | #10 (permalink) |
Freak Poster Join Date: Dec 2001 Location: Earth
Member: 7934 Status: Offline Thanks Meter: 0 | Hi friends, To avoid damaging customer phones you can try the desold and sold PA from a totaly dead phone. So after many times you will be able to remove it and replace it with out any problems. Goood luck |
08-11-2002, 14:32 | #11 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | Thanks alot for your guidance. mujie This method can be realy helpful for the begginers. Do you happen to have some othe info like his and want to let others know it? Thanx LIGHT |
08-12-2002, 09:02 | #12 (permalink) |
Member: 8304 Status: Offline Thanks Meter: 362 | I'm working on uBGA component reworking and replacing,and i'm compiling a 'Quick Tip Guide' on hardware repair like E.G 3210 charging problem,51xx/61xx no network,3310 buzzer,etc. to be released soon with pictures.Can anyone send me a *.pdf file document creator software,will really help alot. |
10-13-2002, 13:04 | #13 (permalink) |
Freak Poster Join Date: Jun 2002 Location: North Pole
Member: 12869 Status: Offline Thanks Meter: 3 | Mujie, thanks for the info, but I still have a problem with Pa replace, taking it off, is quick using your tips but putting it in is still a problem, should I use solder paste 'cos no matter what I do it won't stay on the board, I have used your tips on replacement but no luck, please help!!! |
10-13-2002, 13:17 | #14 (permalink) |
Freak Poster Join Date: Aug 2002 Location: __inside__ Age: 41
Member: 14792 Status: Offline Thanks Meter: 1 | @mujie you can replace hitachi pa instead of philips pa by removing R311..See the old post or have look at MAD&MEMORIES DIAGRAM.. I tried that many times and it worked in all of them...__jero__ |
10-13-2002, 15:16 | #15 (permalink) |
Member: 12869 Status: Offline Thanks Meter: 3 | Do I need an anti-static wrist-band to change Pa, cos mine still sales no access after I put new pa, and this is the second time what could be the problem? |
