03-10-2009, 10:54 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: DERAMOBILE DGKhan pakistan
Member: 388454 Status: Offline Thanks Meter: 1,101 | replacing uem and write Rpl this is the instruction.. this is an actual step by step procedure this is the reading before i change uem... [IMG][/IMG] 1st replace 2ndhand uem...must be good... after changing uem, read the uem in jaf to be sure that the uem you replace is good and to get also the serial number. open your jaf, check then go to imei tool, then read uem.. must be like this.. [IMG][/IMG] |
03-10-2009, 11:11 | #5 (permalink) |
Member: 388454 Status: Offline Thanks Meter: 1,101 | now you have ask file...done.. next is calculating ask file to rpl... go to c, program file, odeon, p-key access..be sure that u have atleast 10 credits or logs to use... do this... [IMG][/IMG] [IMG][/IMG] |
03-10-2009, 11:22 | #6 (permalink) |
Member: 388454 Status: Offline Thanks Meter: 1,101 | all done... you have the rpl.. next and last step is writing rpl to unit... open ufs click check then write uem like stated below.. [IMG][/IMG] after this open your rpl click it then [IMG]12.[/IMG] [IMG][/IMG] this was the whole prosedure................... |
The Following User Says Thank You to shahidsattar For This Useful Post: |
ask rpl and write rpl mathod. | wasim_mobile200 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 06-23-2009 19:03 |
UB box can't read UEM and write RPL for dct4+ etc. | master_tugo | Universalbox | 4 | 03-16-2009 20:25 |
I need full PM to 7373 to write to phone after erase and write rpl | wgmmmx | MT-BOX | 7 | 01-26-2007 11:46 |
IMEI Patch and writing RPL | nutantopno | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 07-19-2006 20:04 |
