04-10-2007, 05:03 | #1 (permalink) |
Freak Poster Join Date: Mar 2007 Location: Ryt Here...Phil Age: 39
Member: 463891 Status: Offline Thanks Meter: 2 | 6020 no backlight ...insert sim Can anyboby give me a good solution..already search the thread none of those help me at all.... |
04-10-2007, 05:37 | #2 (permalink) |
Freak Poster Join Date: Aug 2005 Age: 39
Member: 170684 Status: Offline Thanks Meter: 19 | you are handset may water log clean the pcb fist 1 for back light change the led ic 2 for key pad change the key pad driver ic 3 for insert sim make jumper setting you will have good result. |
04-10-2007, 05:58 | #3 (permalink) | |
Junior Member Join Date: Mar 2007 Location: On the Roof, in the Rain Age: 36
Member: 469717 Status: Offline Thanks Meter: 24 | Right brother Quote:
so plz clean pcb and rehot or change sim ic, keypad ic and light ic | |
04-11-2007, 05:20 | #7 (permalink) |
Member: 463891 Status: Offline Thanks Meter: 2 | Some keys are funtioning ryt now except for 7,8,9 ...already solve the insert sim prob...still no backlight....done the procrdure that u said..other solution... good luck... |
04-11-2007, 15:50 | #11 (permalink) | |
Junior Member Join Date: Nov 2005
Member: 197915 Status: Offline Thanks Meter: 3 | Quote:
try this display connect led+ & Led - Track blue & red line i think this is help for you | |
6020 insert sim pls | NizamSLM | Nokia Hardware & Hardware Repair | 20 | 08-16-2010 08:49 |
Nokia 6020 insert sim | AjayBagdia | Nokia Hardware & Hardware Repair | 0 | 11-10-2006 07:28 |
6020 insert sim | NizamSLM | Nokia Hardware & Hardware Repair | 0 | 07-11-2006 10:31 |
6020 insert sim card | Tetouan Gsm | Nokia Hardware & Hardware Repair | 13 | 05-24-2006 07:54 |
6020 auto off if sim inserted | MARKIE41 | Nokia Hardware & Hardware Repair | 12 | 05-17-2006 23:00 |
