06-01-2010, 10:30 | #1 (permalink) |
Registered User Join Date: Dec 2009 Location: Ghansali
Member: 1188423 Status: Offline Sonork: 100.1636686 Thanks Meter: 18 | RM-436 (Nokia 7210 Supernova) Phone Type: RM-436 (Nokia 7210 Supernova) SW Version: V 07.23 17-07-09 RM-436 (c) Nokia Imei plain: 35318003618747-7 Product Code: 0514950 Language Pack: - not available. SIMLOCK invalid! SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST passed SIMLOCK_DATA corrupted! |
06-01-2010, 10:43 | #3 (permalink) |
Freak Poster Join Date: Apr 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 44
Member: 133201 Status: Offline Thanks Meter: 74 | brother ur mobile in contact service so if u have mxkey or whatever tool which support pm authorisation and sl2 unlocking then just do pm auth and write good pm then unlock it.....1000000 times i repair like this way |
06-01-2010, 10:45 | #4 (permalink) |
Freak Poster Join Date: Feb 2010
Member: 1247853 Status: Offline Thanks Meter: 71 | HERE THE SOLUTION FOR NOKIA 7210C CONTACT SERVICE If after repair SD and/or Simlock (Super Dongle RPL and Simlock RPL upload) you get "SECURITY_TEST failed!" and/or "warning: SD authorized but verify failed!". This is comming usually because some PM fields and/or RPL sections are missing from your phone (e.g. DRM keys, CCC, ...). Solution 1 (easy way, maybe not work all time, depends how phone was damaged): - write full PM from SAME phone model (product number) WITHOUT fields 1, 308, 309 (and WITHOUT field 120 for SL20 based phones) - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 if still have problems, use Solution 2: - backup RPL (NPC, CCC, HWC, ...), will call this ORIGINAL RPL - backup RPL from another working phone (same model) with SAME product code - edit this good RPL from another phone and remove NPC section (all lines who start with NPC_DATA_1 ... NPC_DATA_xx), will call this edited file CLONE RPL - backup full PM from another working phone (same model) with SAME product code, will call this file CLONE PM - full erase flash chip (use erase file regarding flash chip size) - flash phone (CMT, APE, ...) - upload CLONE RPL - upload ORIGINAL RPL - write full CLONE PM without fields 1,120,308,309 - unplug/replug phone from JAF/UFS box - make Simlock RPL repair - make SD RPL repair - unplug/replug phone from JAF/UFS box - make SUPER SX4 Auth then write PM1 and PM309 |
06-01-2010, 10:53 | #5 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: :::::::EMIRATES:::::::
Member: 591669 Status: Offline Sonork: 110011 Thanks Meter: 687 | Quote:
this problem only SIMLOCK_DATA corrupted! no need pm writing and repair SD............. need only update sp lock | |
06-01-2010, 11:01 | #6 (permalink) |
Member: 1188423 Status: Offline Sonork: 100.1636686 Thanks Meter: 18 | when updating splock Updating SIMLOCK...error 0x14 missing NPC data in the RPL file, skipped. please help me iam already many credit loss |
06-01-2010, 11:04 | #7 (permalink) |
Member: 1188423 Status: Offline Sonork: 100.1636686 Thanks Meter: 18 | Writing PM from Node ... Section: 2 - Key: 0, size 432 bytes written. Section: 4 - Key: 0, size 1 bytes written. - Key: 1, size 64 bytes written. - Key: 3, size 10 bytes written. - Key: 4, size 8 bytes written. - Key: 5, size 8 bytes written. - Key: 6, size 8 bytes written. - Key: 9, size 5 bytes written. - Key: 18, size 80 bytes written. - Key: 19, size 4 bytes written. Section: 8 - Key: 0, size 12 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 128 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 8 bytes written. Section: 11 - Key: 0, size 4 bytes written. - Key: 1, size 4 bytes written. - Key: 2, size 4 bytes written. - Key: 3, size 4 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 6 bytes written. - Key: 6, size 2 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 1 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 2 bytes written. - Key: 15, size 2 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 2 bytes written. - Key: 18, size 16 bytes written. - Key: 19, size 32 bytes written. - Key: 20, size 32 bytes written. - Key: 21, size 2 bytes written. - Key: 22, size 2 bytes written. - Key: 23, size 2 bytes written. - Key: 24, size 2 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 2 bytes written. - Key: 27, size 2 bytes written. - Key: 28, size 2 bytes written. - Key: 29, size 2 bytes written. - Key: 30, size 2 bytes written. - Key: 31, size 2 bytes written. - Key: 32, size 2 bytes written. - Key: 33, size 2 bytes written. - Key: 34, size 2 bytes written. - Key: 35, size 2 bytes written. - Key: 36, size 2 bytes written. - Key: 37, size 2 bytes written. - Key: 38, size 2 bytes written. - Key: 39, size 2 bytes written. - Key: 40, size 2 bytes written. - Key: 41, size 2 bytes written. - Key: 42, size 2 bytes written. - Key: 43, size 2 bytes written. - Key: 44, size 2 bytes written. - Key: 45, size 2 bytes written. - Key: 46, size 2 bytes written. - Key: 47, size 2 bytes written. - Key: 48, size 2 bytes written. - Key: 49, size 2 bytes written. - Key: 50, size 2 bytes written. - Key: 51, size 2 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 2 bytes written. - Key: 54, size 2 bytes written. - Key: 55, size 2 bytes written. - Key: 56, size 2 bytes written. - Key: 57, size 2 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 2 bytes written. - Key: 60, size 2 bytes written. - Key: 61, size 2 bytes written. - Key: 62, size 2 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 1 bytes written. - Key: 65, size 4 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 4 bytes written. - Key: 69, size 16 bytes written. - Key: 70, size 4 bytes written. - Key: 71, size 2 bytes written. - Key: 72, size 13 bytes written. Section: 12 - Key: 0, size 102 bytes written. Section: 13 - Key: 0, size 1 bytes written. - Key: 1, size 2 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 2 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 2 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 11, size 48 bytes written. - Key: 12, size 4 bytes written. - Key: 13, size 1 bytes written. - Key: 14, size 1 bytes written. - Key: 15, size 886 bytes written. - Key: 16, size 2 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 1 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 21, size 1 bytes written. - Key: 22, size 1 bytes written. - Key: 23, size 1 bytes written. - Key: 24, size 1 bytes written. - Key: 25, size 2 bytes written. - Key: 26, size 1 bytes written. - Key: 27, size 1 bytes written. - Key: 28, size 1 bytes written. - Key: 29, size 1 bytes written. - Key: 30, size 1 bytes written. - Key: 31, size 1 bytes written. - Key: 32, size 1 bytes written. - Key: 33, size 1 bytes written. - Key: 34, size 1 bytes written. - Key: 35, size 1 bytes written. - Key: 36, size 1 bytes written. - Key: 37, size 4 bytes written. - Key: 38, size 1 bytes written. - Key: 39, size 1 bytes written. - Key: 40, size 1 bytes written. - Key: 41, size 1 bytes written. - Key: 42, size 4 bytes written. - Key: 43, size 4 bytes written. - Key: 44, size 1 bytes written. - Key: 45, size 4 bytes written. - Key: 46, size 4 bytes written. - Key: 47, size 1 bytes written. - Key: 48, size 4 bytes written. - Key: 49, size 1 bytes written. - Key: 50, size 1 bytes written. - Key: 51, size 1 bytes written. - Key: 52, size 2 bytes written. - Key: 53, size 4 bytes written. - Key: 54, size 4 bytes written. - Key: 55, size 1 bytes written. - Key: 56, size 1 bytes written. - Key: 57, size 1 bytes written. - Key: 58, size 2 bytes written. - Key: 59, size 1 bytes written. - Key: 60, size 4 bytes written. - Key: 61, size 4 bytes written. - Key: 62, size 1 bytes written. - Key: 63, size 4 bytes written. - Key: 64, size 4 bytes written. - Key: 65, size 1 bytes written. - Key: 66, size 4 bytes written. - Key: 67, size 4 bytes written. - Key: 68, size 1 bytes written. - Key: 69, size 1 bytes written. - Key: 70, size 1 bytes written. - Key: 71, size 4 bytes written. - Key: 72, size 4 bytes written. - Key: 73, size 1 bytes written. - Key: 74, size 4 bytes written. - Key: 75, size 2 bytes written. - Key: 76, size 2 bytes written. - Key: 77, size 2 bytes written. - Key: 78, size 1 bytes written. - Key: 79, size 1 bytes written. - Key: 80, size 1 bytes written. - Key: 81, size 1 bytes written. - Key: 82, size 1 bytes written. - Key: 83, size 2 bytes written. - Key: 84, size 1 bytes written. - Key: 85, size 4 bytes written. - Key: 86, size 4 bytes written. - Key: 87, size 2 bytes written. - Key: 88, size 1 bytes written. - Key: 89, size 4 bytes written. - Key: 90, size 4 bytes written. - Key: 91, size 2 bytes written. - Key: 92, size 1 bytes written. - Key: 93, size 4 bytes written. - Key: 94, size 4 bytes written. - Key: 95, size 2 bytes written. - Key: 96, size 1 bytes written. - Key: 97, size 4 bytes written. - Key: 98, size 4 bytes written. - Key: 99, size 2 bytes written. - Key: 100, size 4 bytes written. - Key: 101, size 2 bytes written. - Key: 102, size 1 bytes written. - Key: 103, size 4 bytes written. - Key: 104, size 4 bytes written. - Key: 105, size 4 bytes written. - Key: 106, size 4 bytes written. - Key: 107, size 4 bytes written. - Key: 108, size 2 bytes written. - Key: 109, size 4 bytes written. - Key: 110, size 4 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 2 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 1 bytes written. - Key: 116, size 1 bytes written. - Key: 117, size 1 bytes written. - Key: 118, size 4 bytes written. - Key: 119, size 4 bytes written. - Key: 120, size 1 bytes written. - Key: 121, size 1 bytes written. - Key: 122, size 1 bytes written. - Key: 123, size 8 bytes written. - Key: 124, size 1 bytes written. - Key: 125, size 1 bytes written. - Key: 126, size 1 bytes written. - Key: 127, size 1 bytes written. - Key: 128, size 1 bytes written. - Key: 129, size 4 bytes written. - Key: 130, size 4 bytes written. - Key: 131, size 1 bytes written. - Key: 132, size 1 bytes written. - Key: 133, size 2 bytes written. - Key: 134, size 1 bytes written. - Key: 135, size 2 bytes written. - Key: 136, size 1 bytes written. - Key: 137, size 1 bytes written. - Key: 138, size 4 bytes written. - Key: 139, size 4 bytes written. - Key: 140, size 1 bytes written. - Key: 141, size 1 bytes written. - Key: 142, size 1 bytes written. - Key: 143, size 1 bytes written. - Key: 144, size 4 bytes written. - Key: 145, size 8 bytes written. - Key: 146, size 4 bytes written. - Key: 147, size 4 bytes written. - Key: 148, size 1 bytes written. - Key: 149, size 1 bytes written. - Key: 150, size 1 bytes written. - Key: 151, size 1 bytes written. - Key: 152, size 1 bytes written. - Key: 153, size 1 bytes written. - Key: 154, size 1 bytes written. - Key: 155, size 1 bytes written. - Key: 156, size 1 bytes written. - Key: 157, size 1 bytes written. - Key: 158, size 1 bytes written. - Key: 159, size 2 bytes written. - Key: 160, size 2 bytes written. - Key: 161, size 1 bytes written. - Key: 162, size 1 bytes written. - Key: 163, size 1 bytes written. - Key: 164, size 1 bytes written. - Key: 165, size 1 bytes written. - Key: 166, size 1 bytes written. Warning: failed to write 13 - 167 (8 bytes) Warning: failed to write 13 - 168 (4 bytes) Warning: failed to write 13 - 169 (1 bytes) Warning: failed to write 13 - 170 (1 bytes) Warning: failed to write 13 - 171 (1 bytes) Warning: failed to write 13 - 172 (1 bytes) Warning: failed to write 13 - 173 (1 bytes) Warning: failed to write 13 - 174 (1 bytes) Warning: failed to write 13 - 175 (1 bytes) Section: 31 - Key: 4, size 12 bytes written. Section: 42 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. - Key: 17, size 40 bytes written. - Key: 18, size 40 bytes written. - Key: 19, size 40 bytes written. - Key: 20, size 40 bytes written. Section: 50 - Key: 0, size 2 bytes written. Section: 54 - Key: 0, size 2 bytes written. Section: 55 Warning: failed to write 55 - 0 (80 bytes) Warning: failed to write 55 - 1 (2 bytes) Section: 56 Warning: failed to write 56 - 0 (4 bytes) Warning: failed to write 56 - 1 (4 bytes) Section: 65 Warning: failed to write 65 - 0 (11 bytes) Warning: failed to write 65 - 1 (11 bytes) Warning: failed to write 65 - 2 (11 bytes) Warning: failed to write 65 - 3 (11 bytes) Warning: failed to write 65 - 4 (11 bytes) Section: 66 - Key: 0, size 160 bytes written. - Key: 1, size 160 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 160 bytes written. - Key: 5, size 4 bytes written. - Key: 6, size 4 bytes written. - Key: 7, size 4 bytes written. - Key: 8, size 4 bytes written. - Key: 9, size 160 bytes written. - Key: 10, size 240 bytes written. - Key: 11, size 1 bytes written. - Key: 12, size 4 bytes written. - Key: 14, size 4 bytes written. - Key: 16, size 4 bytes written. - Key: 19, size 4 bytes written. - Key: 20, size 4 bytes written. - Key: 22, size 4 bytes written. - Key: 24, size 4 bytes written. - Key: 26, size 4 bytes written. - Key: 28, size 4 bytes written. - Key: 30, size 4 bytes written. - Key: 32, size 4 bytes written. - Key: 34, size 4 bytes written. - Key: 36, size 4 bytes written. - Key: 38, size 4 bytes written. - Key: 40, size 4 bytes written. - Key: 53, size 1 bytes written. - Key: 64, size 8 bytes written. - Key: 65, size 8 bytes written. - Key: 66, size 8 bytes written. - Key: 67, size 8 bytes written. - Key: 68, size 8 bytes written. - Key: 82, size 8 bytes written. - Key: 83, size 8 bytes written. - Key: 84, size 8 bytes written. - Key: 87, size 6144 bytes written. - Key: 88, size 300 bytes written. - Key: 89, size 40 bytes written. - Key: 111, size 4 bytes written. - Key: 112, size 4 bytes written. - Key: 113, size 4 bytes written. - Key: 114, size 4 bytes written. - Key: 115, size 4 bytes written. - Key: 116, size 4 bytes written. - Key: 118, size 4 bytes written. Warning: failed to write 66 - 120 (4 bytes) Section: 67 Warning: failed to write 67 - 0 (2756 bytes) Section: 76 - Key: 0, size 534 bytes written. Section: 84 Warning: failed to write 84 - 0 (3 bytes) Section: 88 - Key: 0, size 36 bytes written. Section: 96 - Key: 0, size 24 bytes written. Section: 107 - Key: 0, size 21 bytes written. - Key: 1, size 89 bytes written. - Key: 2, size 69 bytes written. - Key: 3, size 70 bytes written. - Key: 25, size 132 bytes written. Section: 111 Warning: failed to write 111 - 0 (200 bytes) Warning: failed to write 111 - 1 (20 bytes) Warning: failed to write 111 - 2 (20 bytes) Warning: failed to write 111 - 126 (20 bytes) Warning: failed to write 111 - 127 (20 bytes) Warning: failed to write 111 - 150 (8 bytes) Warning: failed to write 111 - 151 (4 bytes) Warning: failed to write 111 - 152 (40 bytes) Section: 116 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Warning: failed to write 116 - 17 (40 bytes) Warning: failed to write 116 - 18 (40 bytes) Warning: failed to write 116 - 19 (40 bytes) Warning: failed to write 116 - 20 (40 bytes) Warning: failed to write 116 - 21 (40 bytes) Warning: failed to write 116 - 22 (40 bytes) Section: 153 - Key: 0, size 68 bytes written. - Key: 1, size 68 bytes written. - Key: 2, size 68 bytes written. - Key: 3, size 68 bytes written. - Key: 4, size 68 bytes written. - Key: 5, size 68 bytes written. Section: 181 - Key: 0, size 8 bytes written. - Key: 1, size 10 bytes written. - Key: 2, size 1 bytes written. Section: 182 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 183 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 184 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 185 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 186 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 187 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 188 - Key: 0, size 1 bytes written. - Key: 1, size 1 bytes written. - Key: 2, size 1 bytes written. - Key: 3, size 8 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 1 bytes written. - Key: 10, size 1 bytes written. - Key: 13, size 8 bytes written. - Key: 17, size 1 bytes written. - Key: 18, size 8 bytes written. - Key: 19, size 8 bytes written. - Key: 20, size 1 bytes written. - Key: 22, size 8 bytes written. - Key: 23, size 1 bytes written. - Key: 25, size 1 bytes written. Section: 190 - Key: 0, size 355 bytes written. Section: 191 - Key: 0, size 5 bytes written. Section: 193 - Key: 2, size 8 bytes written. - Key: 3, size 32 bytes written. - Key: 4, size 32 bytes written. - Key: 9, size 64 bytes written. Section: 200 Warning: failed to write 200 - 0 (5 bytes) Section: 202 - Key: 0, size 1 bytes written. Warning: failed to write 202 - 4 (42 bytes) Section: 213 Warning: failed to write 213 - 0 (20 bytes) Section: 217 - Key: 0, size 32 bytes written. Section: 218 - Key: 0, size 2 bytes written. Section: 225 Warning: failed to write 225 - 0 (1 bytes) Warning: failed to write 225 - 1 (6 bytes) Warning: failed to write 225 - 2 (6 bytes) Section: 232 - Key: 0, size 20 bytes written. - Key: 1, size 1 bytes written. - Key: 3, size 1 bytes written. - Key: 4, size 1 bytes written. - Key: 5, size 1 bytes written. - Key: 6, size 1 bytes written. - Key: 7, size 1 bytes written. - Key: 8, size 1 bytes written. - Key: 9, size 4 bytes written. - Key: 10, size 1 bytes written. Section: 238 - Key: 1, size 1 bytes written. Section: 250 - Key: 1, size 1092 bytes written. - Key: 2, size 128 bytes written. - Key: 3, size 390 bytes written. - Key: 4, size 36 bytes written. Section: 301 - Key: 0, size 2 bytes written. - Key: 1, size 12 bytes written. - Key: 2, size 36 bytes written. - Key: 3, size 36 bytes written. - Key: 4, size 36 bytes written. - Key: 5, size 36 bytes written. - Key: 6, size 36 bytes written. - Key: 7, size 36 bytes written. - Key: 8, size 36 bytes written. - Key: 9, size 36 bytes written. - Key: 10, size 36 bytes written. - Key: 11, size 36 bytes written. - Key: 12, size 36 bytes written. - Key: 13, size 40 bytes written. - Key: 14, size 40 bytes written. - Key: 15, size 40 bytes written. - Key: 16, size 40 bytes written. Warning: failed to write 301 - 17 (40 bytes) Warning: failed to write 301 - 18 (40 bytes) Warning: failed to write 301 - 19 (40 bytes) Warning: failed to write 301 - 20 (40 bytes) Warning: failed to write 301 - 21 (40 bytes) Warning: failed to write 301 - 22 (40 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Warning: failed to write 309 - 22 (12 bytes) Section: 320 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. - Key: 8, size 148 bytes written. - Key: 9, size 148 bytes written. - Key: 10, size 148 bytes written. - Key: 11, size 148 bytes written. - Key: 12, size 148 bytes written. - Key: 13, size 148 bytes written. - Key: 14, size 148 bytes written. - Key: 15, size 148 bytes written. - Key: 16, size 148 bytes written. - Key: 17, size 148 bytes written. - Key: 18, size 148 bytes written. Section: 321 - Key: 0, size 148 bytes written. - Key: 1, size 148 bytes written. - Key: 2, size 148 bytes written. - Key: 3, size 148 bytes written. - Key: 4, size 148 bytes written. - Key: 5, size 148 bytes written. - Key: 6, size 148 bytes written. - Key: 7, size 148 bytes written. Section: 322 - Key: 0, size 1 bytes written. Section: 334 - Key: 0, size 1 bytes written. Section: 339 - Key: 0, size 511 bytes written. - Key: 1, size 511 bytes written. Section: 341 - Key: 3, size 4 bytes written. - Key: 4, size 4902 bytes written. Completed in 17.375 s |
