04-09-2009, 05:20 | #2 (permalink) |
Freak Poster Join Date: Oct 2006 Location: INDIA TAMILNADU SALEM
Member: 369539 Status: Offline Sonork: 1584109 Thanks Meter: 32 | What is ASK FILE? WHAT IS FLASH RPL? A. as we all know ASK file contains, the ffg. IMEI_ESN and DATA. it's use to request for RPL[4a]. IMEI_ESN is too obvious it has the imei of the unit while DATA contains ASIC number plus the readed FLASH RPL ( if it's still valid, else it needs a new FLASH RPL. ) it's Re-enocded that why we cannot just see the FLASH RPL. we cannot write ASK file. to WRITE u will need a valid DCT4RPL file. FLASH RPL, it has DATA1 this part is written to the FLASH IC w/c the firmware use to validate the imei and watchdog[4b] at UEM IC. if not the same. result would be auto-off (<32sec) or a bad imei ( ????????????4 ). There is a site that will allow u to see the content of your ASK/RPL file.. Old Dct4 has pm208 it contains the FLASH RPL. but new dct4plus dont have it now on PM208. it's been protected from READING via PM. might still be possible to read via Loader way, thou... |
The Following 2 Users Say Thank You to jothi737 For This Useful Post: |
04-09-2009, 05:37 | #4 (permalink) |
No Life Poster Join Date: Dec 2007 Location: shirdi..sai baba.. Age: 36
Member: 662678 Status: Offline Thanks Meter: 2,539 | ASK - used for RPL calculations RPL - RPL is a structured programming language MCU - Master control unit PPM - Post Programmable Memory PM - Permanent Memory RPL File is file wich restore SP Data on BB5 fones in case u dont have Back up also is used to imei repair on BB5 fones with imie:1234567890134 RPL is needed when u try to unlock and the fone shows u this info: CONFIG KEY:FFFFFFFFFFFFFFF or Counter 10/10, 3/3 |
The Following 3 Users Say Thank You to ..::ohm::.. For This Useful Post: |
SIM restriction pending -- what does it mean? | Ryu | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 07-17-2011 10:05 |
what means rpl ??????????? | techno-gsm | Nokia Base Band 5 ( BB-5 ) | 5 | 03-26-2011 13:15 |
RPL means? how can i make back up of rpl of any phone? | nofear99 | Nokia Base Band 5 ( BB-5 ) | 1 | 11-19-2009 05:10 |
Auto-RPL Backup,Write RPL, ASK to RPL for BB5 | matrix05300 | HWK | 0 | 02-28-2007 19:58 |
I mean pc guide for nokia 8210 | linda | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-18-2000 20:49 |
