04-09-2003, 22:36 | #1 (permalink) |
Insane Poster Join Date: Oct 2002
Member: 16859 Status: Offline Thanks Meter: 0 | RSSi reading -144dB solution? NO NETWORRKKKK !!!!!! RSSi reading is -144dB I changed cobba and HAGAR with new one (not chines Mly) But nothing... When I check with RF LED and wintesla TX power no TX power... RX is bad no TX power What can I do any idea??? I don't have scope!!! Thanks |
04-12-2003, 12:07 | #8 (permalink) |
Freak Poster Join Date: May 2002 Location: Craiova, RO. Age: 51
Member: 11493 Status: Offline Thanks Meter: 0 | If when Power On the phone have No Network . .. your problem is PA and Cobba !! if PA is changed .. I forget it .. after changing Cobba and Hagar , you must Repair IMEI, Update Faid, flashing ... etc |
04-12-2003, 22:11 | #9 (permalink) |
Member: 16859 Status: Offline Thanks Meter: 0 | Yes after changin PA and COBBA I flashed phone and calculated FAID But nothing I will try to change 26MHz osc or I will leave from Bulgaria :-) Because I will get crazy I don't have money not only I'm in BG people don't have money... Without a scope it's verrrr difficult to make repair fo mobile phones... Thanks |
04-12-2003, 23:26 | #10 (permalink) |
Guest
Posts: n/a
Member: | You don't need a scope if you have good working BRAIN. Probably, you damaged cobba with hot air. Also check this picture Last edited by legija; 04-12-2003 at 23:33. |
6210 RSSI Readings... | Zoio | Nokia Hardware & Hardware Repair | 1 | 04-24-2003 18:50 |
Low RSSI reading ?!?!?!?! | unlockphone | Nokia Hardware & Hardware Repair | 3 | 04-14-2003 10:35 |
5110 RSSI reading | insidebga | Nokia Hardware & Hardware Repair | 1 | 01-04-2003 16:31 |
RSSI reading. | sjakie | Nokia Hardware & Hardware Repair | 8 | 12-13-2002 00:05 |
Please help with RSSI Reading | mujie | Nokia Hardware & Hardware Repair | 3 | 11-05-2002 17:00 |
