09-21-2008, 18:40 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: karachi
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | ..::nokia 1110i signal comes for seconds & disappear::.. i change pa,make pa jumper,change rf ic 2 times,change filters,and all parts around rf ic,finally i rehot upp but still same also write good pm but the result is same if someone solved this type of problem successfully then plz share with all the members thnx in advanve! |
09-22-2008, 03:17 | #7 (permalink) |
Member: 161728 Status: Offline Sonork: 100.1582708 Thanks Meter: 2,237 | on manual searching it takes very long time for searching maximum 3-4 minutes and after that show all networks and when click for register the network,after few seconds it show "no network access" |
09-22-2008, 18:53 | #10 (permalink) |
No Life Poster Join Date: Apr 2008 Location: sweden
Member: 748544 Status: Offline Sonork: 100.1601881 Thanks Meter: 173 | friend first of all full erase the phone using jaf and then flash again latest ver and then write pm and do factry setting thats all i have tasted two time work fine for me |
11-13-2008, 11:05 | #14 (permalink) |
Registered User Join Date: Mar 2007 Location: kotsultan LY pak
Member: 473907 Status: Offline Thanks Meter: 63 | i have 10 set for no signal. signal area has many many parts we do not know which part is damaged therefore we have to changed every part gradually.then signal come. i think it is v v v v v challenge for all of us. so all mates should share for this strict problem. |
11-15-2008, 22:15 | #15 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | 1110 Signal Brother just change pa (transmetor) your prob will be solved signals coming its mean uem filters are working signals not standby here its mean pa not work |
1110i - 2310 - SIGNAL COMES/ DISAPPEARS on diffirent sims | cel_phon | Nokia Hardware & Hardware Repair | 0 | 07-18-2009 07:20 |
nokia 1110i signal up & down plz hlp | WHED | Nokia Hardware & Hardware Repair | 2 | 03-07-2009 23:27 |
3200 signal come for few second and gone | june_mobile | Nokia Hardware & Hardware Repair | 3 | 05-03-2006 20:50 |
6610 Network Problem. Signal stay for a seconds | baboom | Nokia Digital Core Technology 4 ( DCT-4 ) | 14 | 12-22-2004 07:39 |
6210 & 3310 Network Signal only for few seconds | douda | Nokia Hardware & Hardware Repair | 6 | 06-25-2002 18:02 |
