12-12-2008, 14:45 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 771601 Status: Offline Thanks Meter: 10 | short solution??????????? |
The Following User Says Thank You to sushilkumar For This Useful Post: |
12-12-2008, 16:34 | #2 (permalink) |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | I think you have to explain better what you mean. However, if the charging path is burnt without any shorting of the positive and negative poles of the battery connector, then you need change the charge diode with a simple one you can get from 3310, and run direct wire from the positive interface of the charge pads on the pcb to the positive pole of the diode. |
The Following User Says Thank You to ABUU YUUNUS For This Useful Post: |
nokia 1110 & 1600 short solution | jai2008 | Nokia Hardware & Hardware Repair | 59 | 07-08-2012 07:20 |
Nokia BB5 Short Solution by ichal_spy.. Updated... | Rizal Arsyad Dini | Nokia Hardware & Hardware Repair | 11 | 06-16-2010 18:55 |
