08-18-2007, 13:11 | #1 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | The simplest N70 blank LCD (non complete booted) solution !!! If APE regulator is damaged or rusted then apply jumper 1 . If SYNC/MODE SW is damaged or rusted then apply jumper 2 . If both or for not wasting time then apply both jumpers . & The advantage here is both jumpers can be made with a bit solder no need for wiring as both two jumper points are so closed. Otherwise, it may be APE combo flash IC or processor OMAP fault (unsoldered or damaged) . GΟD bless it >>> |
The Following 37 Users Say Thank You to mobilagy For This Useful Post: |
08-18-2007, 14:12 | #4 (permalink) |
Freak Poster Join Date: Jan 2006 Location: UAE Age: 43
Member: 227127 Status: Offline Thanks Meter: 241 | but bro, there is one more thing http:///vbb/showthread.php?t=423120 i got 2 phones with this fault. |
08-18-2007, 14:32 | #5 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | @ reji , yeah, you are right, that's one more solution if these two points are not measuring together cause they must be in real, but this one has nothing to do with APE regulator neither SYNC/MODE SW faults, it's cause there is cut track to OMAP or unsoldered, great solution buddy >>> |
08-18-2007, 14:49 | #6 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | But you know reji , after a test & measuring i think your jumper is another alternative way for APE regulator , will give it a try next time if mine not works >>> |
The Following User Says Thank You to mobilagy For This Useful Post: |
08-18-2007, 16:29 | #8 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | @ khalifa_smart , smart !!! Since it's new solution so i don't think so, after all it's up to forum management >>> |
08-18-2007, 18:06 | #10 (permalink) | |
No Life Poster Join Date: Oct 2004 Location: USA
Member: 85637 Status: Offline Sonork: 100.100.529 Thanks Meter: 139 | Quote:
nice work and thnx for sharing man and i don't know why there 90 download and just only 3 post thnx again man | |
08-18-2007, 18:28 | #11 (permalink) | |
Registered User Join Date: Apr 2007
Member: 483748 Status: Offline Thanks Meter: 47 | Quote:
remember one thing here is no restriction to show new experince with explination .i know u already submit ur jumper of repairing the white screen.i think ur jumper is good for some mobile phone but not for all . instead of appreciation u depreciat a person it is not sign of a good human being . see ur image and also see his u will find a difference. Last edited by xtremeburaq; 10-13-2008 at 06:11. | |
The Following User Says Thank You to xtremeburaq For This Useful Post: |
08-18-2007, 21:01 | #12 (permalink) | |
No Life Poster Join Date: Nov 2006 Location: guangzhou,CHINA & delhi,INDIA
Member: 399779 Status: Offline Thanks Meter: 125 | Quote:
By puneet1484, shot with N90-1 at 2007-07-22 | |
The Following 4 Users Say Thank You to puneet14884 For This Useful Post: |
08-19-2007, 03:39 | #13 (permalink) |
Member: 217479 Status: Offline Thanks Meter: 267 | @ puneet14884 , thanks for sharing, but why spoil my thread with such big picture size dimensions ?!!! I think you have your own thread where you have posted that solution, haven't you ??? You may have attached just link to it. By the way, that component you called "SAMSUNG SD RAM" is in real combo flash chip not SD RAM !!! |
08-19-2007, 07:56 | #14 (permalink) | |
N70 Complete Hardware Solution And More Nokia Solution Is Here | GsmunlockArena | Nokia Hardware & Hardware Repair | 1 | 07-07-2009 07:48 |
N70 blank lcd | AS_ADNAN440 | Nokia Hardware & Hardware Repair | 5 | 06-29-2009 07:06 |
N70 hot panel and blank LCD | Emeka.gsm | Nokia Hardware & Hardware Repair | 2 | 03-28-2009 20:34 |
n70 blank lcd | bearhug | Nokia Hardware & Hardware Repair | 5 | 09-12-2008 14:47 |
n70 blank lcd | simonmanju | Nokia Hardware & Hardware Repair | 2 | 08-26-2007 11:37 |
