Old 08-09-2004, 19:27   #1 (permalink)
Member: 7444
Sonork: 100.99999
Thanks Meter: 10,013
SO STRANGE 3310 , Experts pls help!
Today we`ve got a 3310 with no ring,
so i shorted pin 6 of user-interface-ic (ic with 20 legs) to buzzer connector, now ring is working , but another problem happened!
when i turn OFF vibrator in menu, when phone ringing, it rings for 10 seconds without vibrate, but then vibrator starts to work!!!
when i turn ON vibrator, vibrator is always working (OK)
when i remove short from pin6&buzzer, then again no ring, but vibrator will be ok (vibrator not work when i turn it off)
any help?
Old 08-09-2004, 19:40   #2 (permalink)
Chris02's Avatar
Member: 41076
Thanks Meter: 53
I think the connection between Pin 6 and buzzer pad was bad. Any short circuits.
If that was ok change UI!
Old 08-09-2004, 19:57   #3 (permalink)
gibso's Avatar
Member: 25150
Thanks Meter: 8
if the connection is ok ( no short circuites)
the you have to change the 20legs IC
goodluck
Old 08-09-2004, 20:56   #4 (permalink)
SRNOURI's Avatar
Member: 29870
Thanks Meter: 24
Dear vahid
I agree with gibso.change interface IC first (I think you changed it until now).Otherwise clean good under ccont IC(May water dropped).
Old 08-09-2004, 22:38   #5 (permalink)
Member: 39601
Thanks Meter: 13
No it may not be water effect , the problem is either a software problem ( firmware bug ) or an iternal failuer in the N400 driver chip occeurs after it warmesup during the 1st 10sec.
Old 08-10-2004, 02:21   #6 (permalink)
Member: 76877
he he he he ...............................
change ur stepup ic...................
bye
Old 08-10-2004, 07:16   #7 (permalink)
Member: 7444
Sonork: 100.99999
- Connection between pin6 & Buzzer is 100% ok.
- N400 already changed (twice!)
- CCONT is ok.
- phone has been full flashed with different versions, even v6.33!
so, any other idea?
Old 08-10-2004, 20:05   #8 (permalink)
SRNOURI's Avatar
Member: 29870
Thanks Meter: 24
Dear Vahid
Please check two pin of vibrator in pcb with multimeter or ohmmeter and compare with safe pcb .If there is different and masurment be under 150 ohm you pcb has short line in middle layer and for fix it you should replace N400 and then with strong power supply should input 15 volt in vibrator pin for about 30 seconds and then put N400 again and with othere wire you should repair lane of vibrator.I think you can get result with this solution(I hope).sorry for my ENG.
With best regards
SeTool experts pls help me.... lolan SETool2 23 01-13-2009 09:22
Need flash for nk63100 expert pls help me NightPrince Nokia Digital Core Technology 4 ( DCT-4 ) 1 04-02-2007 20:39
Gd87 Strange Problem !!!!!!!!!! Experts Pls Help... VsH-GsM Panasonic 13 10-27-2005 12:23
my x5 experts pls help one problem komix ARM9 BASED M62 / M62+ 27 05-21-2003 09:39
Need Id For My X-5 Sagem Experts Pls Help komix Phone Unlocking Codes & Maps 11 11-06-2002 06:48
Page generated in 0.16804 seconds with 9 queries
