02-02-2005, 03:20 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: dasma cavite Age: 46
Member: 78367 Status: Offline Thanks Meter: 11 | solution on 8210 no power but charging and flashing due to water damaged!!!!!! 1. check lines between keypad possitive line #3 or #6, #9 and v360. if lines broken jump it wire. if not ok... 2.(this is important) there is a thin line horizontally parallel to the right side keypad #3, #6, #9 that is the only line between v360,#3,#6,#9 to the cpu. slightly scratch line test it if there is continuity... if there is not, jump it..... problem solved! note if there is continuity? hmmmmm MAD line are broken..... hope it helps.... |
nokia 6630 no power but charging | bd electronics | Nokia Base Band 5 ( BB-5 ) | 12 | 01-08-2009 11:56 |
6280 no power but charges | shawgsm | Nokia Hardware & Hardware Repair | 9 | 12-29-2007 18:07 |
Pls help! M35 no power, but charging... | Dj King | x1x to x45/x50 | 10 | 04-04-2003 19:44 |
dead 3310 due to water damage | Black-Axe | Nokia Hardware & Hardware Repair | 1 | 02-04-2003 11:47 |
6210 No power But charge | alrbee | Nokia Hardware & Hardware Repair | 6 | 08-22-2002 19:14 |
