Old 12-13-2004, 01:58   #1 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
solution require for broken BGA pads
Hi all
I face frequent problem after removing BGA IC. When I clean the pads with iron and desolder-wick, some pads peel-off from its place.
Can anybody tell me how to fix this problem ?
Thanks in advance.
Regards.
Old 12-13-2004, 08:43   #2 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
1. Don't use desolder wick....Just clean pads with soldering iron tip, it is good enough
2. Do not exceed 250 degrees celsius
br
vule
Old 12-13-2004, 09:13   #3 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
With soldering iron tip?
Old 12-14-2004, 19:56   #4 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
@ Mr.Vule
Thanks for reply. OK I accept it but in case if pads are peeled off then how to fix the problem ? I tried to take a thin wire and soldered it to IC and then soldered the IC to its place but all the time the thin wire tends to displace when get heated. What care shoul I take ?
If anyone have solution please guide me. Thanks.
Regards...
Old 10-14-2005, 16:34   #5 (permalink)
Member: 30205
Thanks Meter: 4
Originally Posted by rajumobile
@ Mr.Vule
Regards...
the best way to fixe that type of problem demand a lot practice
-have a good quality of solder paste
-have a good knife to clin the broken tract
-clean your tract softly until you see the wire in the small hole
-put a little bit of paste and heat it up whit your hot-air until you have ball
-press it down with a twiser or a pice of metal until you it get the shap other track
The Following User Says Thank You to bakoume For This Useful Post:
Old 10-14-2005, 16:45   #6 (permalink)
Member: 30205
Thanks Meter: 4
br
vule
the solder wick is very helpfull.but some people should know how to use it.
1-the difficult problem is what type of soldering machine that we use
2-have you got a good one with a nice clean tip
3-your temperature is good enough to clean the board
6300 water damaged for sim bga pad crazyman Nokia Hardware & Hardware Repair 0 04-28-2008 17:25
Solution Required for Contact Retailer in 6600 ajubaba Nokia Hardware & Hardware Repair 7 08-05-2006 11:59
--== SonyEricsson T610 broken switch pad solution ==-- CyberGSM Sony Ericsson Hardware Repair 6 06-16-2006 05:11
V200 Broken SIMCARD PAD bobbie_mcp Samsung Hardware Repair 0 06-11-2005 13:55
Page generated in 0.27950 seconds with 8 queries
