Old 10-20-2005, 05:26   #1 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
solutions can't local mode,test mode,normal mode after reflash in here
did any body have solutions i have much case phone cant local mode,test mode,and normal mode after 100% work reflashing
for example my 3650,3660,6220,6610,6600,6630,QD,3100
all work ok! when reflashing, but after reflashing when need to ui setting etc. always have error massage "Init Local Mode Failed" etc
if any body have a solutions,experience,picture or etc please upload here........
regards
Old 10-20-2005, 07:04   #2 (permalink)
Moderator
oblio's Avatar
Member: 59869
Thanks Meter: 120
it is a quite long list, maybe you do something wrong(ex: downgrade, MCU not same version as PPM, bad cables, broken M-bus line in box connector etc).Next time, put a log or a screenshot here, to see the error.
The Following User Says Thank You to oblio For This Useful Post:
Old 10-20-2005, 18:43   #3 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
i had been do anything and i try with other phone and my cable work normaly no have problem with my cable and FW.
regards
Old 10-21-2005, 20:36   #4 (permalink)
gsmjunction's Avatar
Member: 104847
Thanks Meter: 5
ui setting fail due to cable change the cable or value of resistor in the cable
Old 10-21-2005, 21:02   #5 (permalink)
sam unlocker's Avatar
Member: 14632
Thanks Meter: 32
try this it well help you good luck
File Type: jpg 3100_localmode_with_battery_solution2.jpg (82.0 KB, 1614 views)
Old 10-22-2005, 07:24   #6 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
NO MY FRIEND THE PROB IS NOT LOCAL MODE WHEN INSERT BATTERY BUT NO LOCAL MODE AFTER REFLASHING
REFLASHING PROCESS IS FINISH TO 100% BUT USSUALY AFTER REFLASH SHOWING LOCAL MODE OR NOKIA LOGO ON THE PHONE SCREEN,BUT ON THIS CASE NO LOCAL MODE OR NOKIA LOGO ON THE SCREN AFTER REFLASH.
I TRY TO UI SETTING,LOCAL MODE,TEST MODE,NORMAL MODE AND ALL FAILED REPORT
REGARDS
Old 10-22-2005, 21:44   #7 (permalink)
Member: 14632
Thanks Meter: 32
had you erase your phone with special file erase; and after flash your phonenormaly .
i thing it's soft prob .
if prob not resolved try flash with another version
good luck
Old 10-23-2005, 10:53   #8 (permalink)
Member: 127198
REGARDS
I know this problem, but now i have not solution, i'm trying to understand how to do.
B.R.
Old 10-23-2005, 18:22   #9 (permalink)
Member: 168352
Thanks Meter: 17
try with another version or another installer
Old 10-24-2005, 08:37   #10 (permalink)
inat's Avatar
Member: 149576
Thanks Meter: 56
cant localmode
regards
mostly hardware problem, SRAM replace no reheat.
Old 10-24-2005, 13:50   #11 (permalink)
Member: 77186
what kind of software you are using to flash the phone??? check your cable...
The Following User Says Thank You to mjane For This Useful Post:
Old 10-26-2005, 22:21   #12 (permalink)
uwenk98's Avatar
Member: 16904
Thanks Meter: 9
i use jaf.griffin and ufs but still same
Old 10-31-2005, 15:11   #13 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
how about 6630 always in test mode what could be wrong
Old 11-21-2005, 18:57   #14 (permalink)
gama_cell99's Avatar
Member: 92067
Thanks Meter: 10
so many prob of cant local mode after reflashing is from RAM...........?????
Old 11-22-2005, 10:19   #15 (permalink)
blu angel's Avatar
Member: 168090
Thanks Meter: 92
regards
if the phone is still working when you still did not re flash it and when u do it doesn't come to local mode or can't reboot to normal mode anymore, then ur problem is only in sofware,maybe there's a mismatch in the MCU and PPM..just try to check it.
but when the phone is dead and is still dead when you reflash it then ur problem is in hardware,mostly it was on RAM but sometimes it can also be ROM or the UEM..
flash,local mode,test mode,normal mode big problem need help gsm_cdma_ufs Nokia Hardware & Hardware Repair 0 04-10-2009 10:50
1600 fleshing ok local mode/test mode ok but normal mode fail zargar322 Nokia Hardware & Hardware Repair 9 03-31-2008 16:22
can't in Local or Test mode paimai51 BB5BOX 2 10-08-2007 05:50
Test mode, Local mode Normal mode royke Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-13-2002 11:33
Page generated in 0.40885 seconds with 9 queries
