11-28-2005, 08:45 | #1 (permalink) |
Freak Poster Join Date: Jan 2002 Location: India Age: 48
Member: 8587 Status: Offline Thanks Meter: 4 | Solve this 6600 riddle...... Both when tried to flash through UFS threw 2nd boot error...... Changed the SRAM and everything went well with flashing But the problem is the "NOKIA" text stays there in the screen permanently.... I try changing the UPP, another SRAM, R385, N380... But its all the same..... This is strange to me I have not come across this sort of problem before in 6600.. If I click init normal mode with UFS while mode changing it flashes "contact retailer" for sometime and gets into "insert sim card" but with a battery I am not able to boot the mobile into normal mode. Willy I had tried your boot up troubleshooting document even which says to flash with PPM software for this problem.... But no improvements Will be greatful if somebody can help me.... Thanks Ciao. |
11-28-2005, 13:23 | #2 (permalink) |
Freak Poster Join Date: Oct 2005
Member: 193959 Status: Offline Thanks Meter: 22 | flash it letest ver.if tha prob still than use griffin box and first detct phone than go sepacial function and 1st click on factory set LM 2nd click factory set default.or full flash with griffin |
11-28-2005, 14:05 | #3 (permalink) |
No Life Poster Join Date: Mar 2000 Location: inside NOKIA phone Age: 58
Member: 1060 Status: Offline Thanks Meter: 10 | @Ciao if you can see the boot up NOKIA logo, then you have to make your flash cable "force local mode" ! check cable replace BSI to GND resistor, make sure it 3.58Kohm, then boot up phone , then do "self-test" also check FLASH ID:00 that flash rom., and make sure 007F0000-007FFFFF can be "earse/read" ! Willy |
11-28-2005, 15:14 | #4 (permalink) | |
Member: 8587 Status: Offline Thanks Meter: 4 | Quote:
So as you said I did and got some Results from Griffin Selftests Passed - ST_UPP_REGISTER_VER_TEST Passed - ST_UEM_CBUS_IF_TEST Not executed - ST_SLEEP_X_LOOP_TEST Not executed - ST_AUX_DA_LOOP_TEST Passed - ST_EAR_DATA_LOOP_TEST Passed - ST_TX_IDP_LOOP_TEST Not executed - ST_TX_IQ_DP_LOOP_TEST Passed - ST_SIM_CLK_LOOP_TEST Passed - ST_SIM_IO_CTRL_LOOP_TEST Passed - ST_MBUS_RX_TX_LOOP_TEST Passed - ST_BACKUP_BATT_TEST Not executed - ST_KEYBOARD_STUCK_TEST Not executed - ST_LCD_TEST Not executed - ST_LPRF_IF_TEST Not executed - ST_LPRF_AUDIO_LINES_TEST Not executed - ST_CAMERA_IF_TEST Not executed - ST_EXTERNAL_RAM_TEST Not executed - ST_IR_IF_TEST Not executed - ST_VIBRA_TEST Not executed - ST_KEYB_LINE_TEST Not executed - ST_RF_CHIP_ID_TEST Fail - ST_ZOCUS_CBUS_IF_TEST And the below is the screen shot of UFS which shows Flash ID of the four chips and the erasing completed for the address you mentioned 1st Boot Ok, WD2, UPP: 1081 Fl0: 0x00000000-0x007FFFFF,002088C0,St M28W640 Fl1: 0x02000000-0x027FFFFF,002088C0,St M28W640 Fl2: 0x04000000-0x047FFFFF,002088C0,St M28W640 Fl3: 0x06000000-0x067FFFFF,002088C0,St M28W640 Algorithm: w3_st_i.fia, w3_cbusb.fia, Ver: 4.47.2 Area1: 0x007F0000-0x007FFFFF Erased, Time: 00:01 Now can you guide me what to do... By the way my member name is abibaby and Ciao is a greeting word. More about that here http://dictionary.reference.com/search?q=ciao Ciao Last edited by .:*CHENNAI GSM*:.; 11-28-2005 at 15:25. | |
11-28-2005, 18:12 | #5 (permalink) |
Member: 1060 Status: Offline Thanks Meter: 10 | it already clear , that "zocus" line for CBUS test ,,,, not pass try to measure the 1Mhz clk,, also check line cut ..if all ok, then replace zocus ! **************************** Passed - ST_UEM_CBUS_IF_TEST Fail - ST_ZOCUS_CBUS_IF_TEST **************************** you need to make this test , special for EXT SRAM : ST_LPRF_IF_TEST ST_EXTERNAL_RAM_TEST ST_IR_IF_TEST ST_KEYB_LINE_TEST **************************** the past time, if zocus not working , you can see "color line" on LCD, blinking for 8 times after you press power on key ! Willy |
01-01-2007, 22:26 | #6 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: iraq
Member: 231662 Status: Offline Sonork: 1607488 Thanks Meter: 390 | Quote:
can you sure from this ? blinking for 8 times === zocus is there another choice ?? my dear Tc | |
01-02-2007, 19:18 | #7 (permalink) | |
No Life Poster Join Date: May 2006 Location: U wont beleive Age: 43
Member: 275631 Status: Offline Thanks Meter: 408 | 6600 strange Quote:
01-04-2007, 09:27 | #8 (permalink) | |
Freak Poster Join Date: Aug 2004
Member: 76716 Status: Offline Thanks Meter: 15 | Yes Quote:
Khalifa Smart is very smart. He is absulately right. I've changed this ic from my old set in 3 to 4 cases. So go through that. | |
01-17-2007, 07:22 | #9 (permalink) | |
Junior Member Join Date: Aug 2004 Location: Where i belong
Member: 76726 Status: Offline Thanks Meter: 0 | Quote:
i cant rum new polar plastico please solve this probleme??? [SOLVED] | yassinek85 | PolarBox 3 | 4 | 02-24-2010 16:04 |
How to solve this.......... [SOLVED] | Kiranmistry | Cyclonebox | 6 | 11-21-2009 16:45 |
how can i solve this error (BB5 Unlock Failed->Failed to get Lock Key (6, 5) [SOLVED] | zamobe | Cyclonebox | 11 | 11-19-2009 19:25 |
And Another Telcel !!!!please Solve This!!! - >> problem solved << | jjrock | NoooX Box | 20 | 09-23-2008 20:14 |
6600 white display v140 ic brocken how to solve this problem? | CHAPRAN | Nokia Hardware & Hardware Repair | 8 | 02-04-2007 19:56 |
