Old 04-16-2003, 17:45   #1 (permalink)
Member: 23790
Question can plz someone explain what means watchdog is grounded?
hi pipl,
just got my jig delivered and now i got to the point where i need to check something with watchdog grounded and =0...what is this excatly...can someone explain 2me
cheers
roman
Old 04-16-2003, 22:00   #2 (permalink)
Member: 14004
Thanks Meter: 6
On 3310, on front bottom side of the board (keypad side), there are contacts used for service testings. PIN 9 is WDDISCX (watchdog disable)... I think it must be grounded for some testing ... but maybe someone knows more about this...
Old 04-17-2003, 01:05   #3 (permalink)
Member: 23790
aliright...ic...will give a try 2morrow...ops...i mean later on today alreadythnx...better than nothin...what ive done in meant time...i just tried GND to R224 and + to C316...and even got 2.8V
Old 04-17-2003, 01:09   #4 (permalink)
Member: 23790
but then if i follow service manual fault finding chart im coming to faulty ccont...which is not any good 2me as i dont know how to check when ccont is faulty...or working...so im in stuck with millions of my 33xx...another fault i found is very common that R220=0...but must be 3.6v...dont know if there is way around this problem...or just change it....
Old 04-17-2003, 21:59   #5 (permalink)
Member: 23790
if anyone interested i found out that jig's have their own pin connected to watchdog and gnd already...all i needed to do is to find it...and johny u were right...so...i was just stupid
Old 04-17-2003, 22:31   #6 (permalink)
Member: 14004
Thanks Meter: 6
No, you are not stupid, you are just learning, like we all do
Old 04-17-2003, 22:36   #7 (permalink)
Member: 23790
yeah...like today...first time reballed ccont from scrap...it doesnt matter that phone still deadcoz i think its dead ccont or pcb is faulty...coz voltage on all test points is ok...
Old 04-18-2003, 15:30   #8 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
Hiya
Here we go....
When phone normally powers up and software is initialised, watchdog must be served every 8 sec ( short pulse from 1 to 0 ) by software or ccont will power phone down after 30 sec from last pulse
When You disable watchdog by connecting wddisx to ground, ccont can't power phone down so You can run check and tests of signals...
Vule
Old 04-18-2003, 15:52   #9 (permalink)
Member: 23790
icccc....very interesting...thnx vule...good stuff...
Old 04-18-2003, 16:54   #10 (permalink)
Springer's Avatar
Member: 15909
If phone is ok, and wddisx gronded, then phone switch on.
Or no?
Old 04-18-2003, 22:14   #11 (permalink)
vule's Avatar
Member: 10854
Sonork: 1578988
Thanks Meter: 3
No...But if phone is in working condition You can switch it on with BTEMP....
Vule
can ANY ONE explain what the 3rd party sofware sayedhas HWK 8 02-17-2008 13:46
can any one explain what is tsp scratching ? imran_k Siemens Hardware Repair Area 1 09-08-2004 11:52
Can someone explain what to recognize languages in various versions angele Infineon C16X M51 & ARM7 M52 BASED 2 01-18-2004 23:39
please explain what mean errors in gd55 orig flasher doctorvatson Panasonic 2 09-16-2003 11:57
Can somebody explain what ic2 cable is??? ronkor2000 Samsung Flashers, Software, Firmware. 12 10-28-2001 07:29
Page generated in 0.31165 seconds with 10 queries
