Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 04-29-2009, 08:50   #1 (permalink)
Member: 481933
Sonork: 100.1582701
starnge problem in nokia 2680 autooff
today i recieve a handset nokia 2680 in autooff possition in after 30 sec . first i clean the pcb then reball power module & also replace rtc but problemis same . also i flash the handset with latest ver . finely i am going to abt dct4+ rpl service for this problem . if any body have alter solution then welcome to share this to me .
any body face this problem pls share to me thanks in advance
b/r vicky
nazar2008
The Following 5 Users Say Thank You to nazar2008 For This Useful Post:
Old 05-01-2009, 05:41   #2 (permalink)
Member: 344164
same problem to me is there any solution for this
The Following 2 Users Say Thank You to jack81 For This Useful Post:
Old 05-01-2009, 06:10   #3 (permalink)
kapilgupta's Avatar
Member: 681945
its watchdog function is active now,u have to write full pm without sx4.
The Following User Says Thank You to kapilgupta For This Useful Post:
Old 05-12-2009, 08:03   #4 (permalink)
Member: 481933
Sonork: 100.1582701
thanks for reply man but i want to remember that nokia 2680 is not a bb5 series handset its dct4+ handsetset so no nead to sx4 for writer full pm .
thanks
b/r vicky
Old 05-12-2009, 10:22   #5 (permalink)
laddimobile's Avatar
Member: 672494
Exclamation 2680 auto off
same problem plzz help me
The Following User Says Thank You to laddimobile For This Useful Post:
Old 05-12-2009, 17:25   #6 (permalink)
Member: 481933
Sonork: 100.1582701
most of my friends have this problemin this handset so pls forem member give here the right solution of this fault .
thanks in advance
b/r vicky
Old 05-18-2009, 20:02   #7 (permalink)
Member: 275290
i have same problem and another one with no back light.
thank in advance.
Old 05-19-2009, 08:13   #8 (permalink)
kapilgupta's Avatar
Member: 681945
thank in advance.
check light ic and quil
Old 05-25-2009, 20:02   #9 (permalink)
Member: 275290
thanks.
give me diagram of the ic.
Old 09-26-2009, 06:59   #10 (permalink)
Phantom's Avatar
Member: 1133
same auto off problem here
Old 09-26-2009, 07:10   #11 (permalink)
jagdish puri's Avatar
Member: 573120
no other solution bro have to write rpl or can be uem problem .
Old 10-12-2009, 17:52   #12 (permalink)
usman0000's Avatar
Member: 132635
i hv two 2680s auto off but with charger its work fine
but with out charger its auto off
hv any one solution????????
Old 10-12-2009, 17:55   #13 (permalink)
usman0000's Avatar
Member: 132635
Getting MCU ID
MCU ID: 0x3162
FLASH ID0: 883C0020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: AD 7E B6 1B 00 FF 10 40 00 00 00 00 00 00 00 00
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
P-key nokia module version 01.02
Done!
Phone Restarted...
Checking path: D:\Program Files\Nokia\Phoenix\products\RM-392\
Searching for default location of ini...
Checking path: D:\Program Files\Nokia\Phoenix\Products\Products\RM-392\
Searching for JAF saved location of ini...
No ini files found...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: D:\Program Files\Nokia\Phoenix\products\Rm-392\rm392__06.17.mcusw
Phone Type:
PPM Flash file: D:\Program Files\Nokia\Phoenix\products\Rm-392\rm392__06.17.ppm_el
Phone Type:
CNT Flash file: D:\Program Files\Nokia\Phoenix\products\Rm-392\rm392__06.17.image_el
MCU: D:\Program Files\Nokia\Phoenix\products\Rm-392\rm392__06.17.mcusw
Booting phone...
MCU ID: 0x3162
BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia
Loader version: 04.46.01 -> Revision: 0007
Boot size is 0x09A8
Boot is ready...
FLASH ID1: 883C0020 <=> ST -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 11
Flash ID is 0x3C882000
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
Loader size is 0x5548; Loader chk: fe
Loader is ready...
MSID: 84F22B594873DAFA6EFBB7ED0C
MSID decoded: 2C40BAE90005EEFFA9000000
FAID: E365EB30286C109C672D267D
Operation took 0 minutes 10 seconds...
Erasing...
Found 2 interval(s) to erase
Erasing area: 01000000 - 0101FFFF...
Erasing area: 01020000 - 01CFFFFF...
Operation took 1 minutes 59 seconds...
Writing...
Perm. Data Restore OK
Operation took 1 minutes 13 seconds...
Restarting MCU...
CNT: D:\Program Files\Nokia\Phoenix\products\Rm-392\rm392__06.17.image_el
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
File is already converted to 128k page...
Loader is ready...
MSID: 844C157FA1E5423EA46964CCDA
MSID decoded: D26EBAF10005EEFFAA000610
FAID: 3AB96DC06098E5424D93A935
Operation took 0 minutes 7 seconds...
Erasing Content Pack...
Erasing area: 02180000 - 02E7FFFF...
Erasing area: 02E80000 - 02FBFFFF...
Operation took 4 minutes 20 seconds...
Writing...
Operation took 0 minutes 23 seconds...
Restarting MCU...
Operation took 0 minutes 0 seconds...
Extracting Content Pack...
Running: (c) Nokia File Server
CNT Extract OK.
Operation took 0 minutes 5 seconds...
PPM: D:\Program Files\Nokia\Phoenix\products\Rm-392\rm392__06.17.ppm_el
Booting phone...
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84E135BD44158DD0E4CD5A3741
MSID decoded: 3E4EBAE90005EEFFA8000000
FAID: C1531526A8ADFB991809508F
Erasing PPM...
Found 1 interval(s) to erase
Erasing area: 01D00000 - 0217FFFF...
Operation took 0 minutes 55 seconds...
Writing...
Operation took 0 minutes 13 seconds...
Restarting MCU...
Flashing Done!
Operation took 9 minutes 46 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RM-392, Software version: 06.17
IMEI: 356390027996110
Product Code: 0564368
Resetting PPC...
Setting FULL FACTORY......Setting test mode...
Operation took 0 minutes 4 seconds...
Done!
Done!
Powering the phone...
Unlocking...
ASIC: b
SW version: 06.17
Selected flash file: D:\Program Files\Nokia\Phoenix\products\Rm-392\rm392__06.17.mcusw
Decrypting flash...Done
Checking ROM call...Done
Checking security function...Done
Encrypting....Done
Patch status: 00
MCU ID: 0x3162
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing area: 01080000 - 0109FFFF...
Failed! Aborting!
Done!
Old 10-27-2009, 09:24   #14 (permalink)
Member: 142994
i have exactly same problem after 30 sec auto off.... i flashed but same....any solution plz
The Following User Says Thank You to manish1234 For This Useful Post:
Old 10-28-2009, 06:42   #15 (permalink)
kapilgupta's Avatar
Member: 681945
dc4+ phones watchdog problem(auto off after 30 sec) can solve by 2 ways, first try with new rpl and pm, if not done then change uem ic
this is the final solution
The Following 2 Users Say Thank You to kapilgupta For This Useful Post:
problem in nokia 2680 ranagaurav MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 04-12-2010 09:58
Problem unlock Nokia 2680s!!!! tommyvo Cyclonebox 4 05-28-2009 11:45
if you have a problem in nokia hardware post here i will help you in 24 ours vash_three:16 Nokia Hardware & Hardware-Repair Area 111 11-25-2008 08:59
Page generated in 3.36135 seconds with 12 queries
